• Support PF! Buy your school textbooks, materials and every day products Here!
Spring constant question
  • Thread starter NoHeart
with no friction- what spring constant would fire a 10 g mass to a height of 100 m. the spring is compressed to 10 cm.
i know k=F/x but i don't know how to find the force for this problem, because i need to find the acceleration and there is no time unit given. any help???
jamesrc
You don't really need to consider the force. What is the potential energy stored in the spring before it is released? What is the potential energy of the mass when it reaches its maximum height? What is the relationship between those two quantities? I hope you see what I'm getting at.
3,761
Use conservation of energy. The potential energy of a spring that has been compressed over a distance x is kx²/2
You also know that at the 'end' of the motion, the object must be 100m above the horizontal. This corresponds to a potential energy of mg100 (due to gravity)...
regards
marlon
quasar987
Read the question in terms of energy. What must be the force F=kx such that the work
[tex]W = \int_{0}^{0.10} kx dx [/tex]
done by it over 10cm is equal to the potential energy associated with an height of 100m above the surface of the earth?
how do i find the potential energy of the spring if i don't know the spring constant?
3,761
like i said, the potential energy is kx²/2. You can prove this formula by integrating the force wtr displacement x, but that's not necessary.
You will need this formula to find k...
marlon
dextercioby
Insights Author
12,960
536
U need to know the minimum velocity needed for the body to reach 100 m in a constant gravity field.
Daniel.
3,761
Daniel.
Nope, that is not necessary...
marlon
3,761
dextercioby said:
What?
Daniel.
You don't need to know the minimal velocity.
marlon
28
thanks so much for the help everyone, i hope i'm understanding now...
so the potential energy of the object when it reaches a height of 100m is mgh, .01kg x 10m/s^2 x 100m=10Nm=10J
is the potential energy of the object equal to the potential energy of the spring? if so, i have 10Nm=(k(1m)^2)/2 and k=20N/m
please tell me i'm at least on the right track...
3,761
That is correct
yes indeed, that's the clue of the story
Beware, the compression is 10 cm NOT 1m !!!
marlon
dextercioby
Insights Author
12,960
536
Okay,Marlon,gravity field is conservative,so you could use the PE,too_Okay.
Daniel.
28
thank you so much, marlon. 10cm is .1 m, jeez! at least i know how to do this problem now...
Related Threads for: Spring constant question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
19K
  • Last Post
  • Last Post
