Spring energy question
In summary, a 300g mass dropped from a height of 40cm onto a vertical spring with spring constant 200N/m will compress the spring by .124m. For part (b), the correct answer for the spring's stretch cannot be determined without finding the equilibrium point and treating the problem as a harmonic oscillator.
John O' Meara
330
Suppose a 300g mass is dropped from a height of 40cm onto a vertical spring with spring constant 200N/m (having a light platform on top) and sticks to the platform (a) How far will the spring compress? (b) How far will the spring be stretched as the mass and spring rebound? use S.I. units.
I can do part (a) ans = .124m. For part (b) I cannot get right answer =.095m
Us at the bottom = Ug at end
where: Us = potential energy of the spring
Ug = potential energy of gravity
this gives:
.5kx^2 = mgx
=> .5kx = mg
= wrong result
what am I missing,
Thanks & regards
If you have done part a) correctly, you know the lowest point of the motion of the mass attached to the spring. If you find the equilibrium point, you can treat the rest of the problem as a harmonic oscillator with an initial displacement starting with zero velocity.
In order to solve for the distance that the spring will be stretched in part (b), you need to consider the conservation of energy in the system. When the mass is dropped onto the spring, it will compress the spring and gain potential energy. This potential energy is then converted into kinetic energy as the mass and spring rebound, and eventually back into potential energy as the mass reaches its maximum height again.
So, in order to solve for the distance the spring will be stretched, you need to equate the initial potential energy gained by compressing the spring to the final potential energy gained when the mass reaches its maximum height.
Initial potential energy: Us = 0.5kx^2 (where x is the distance the spring is compressed)
Final potential energy: Ug = mgh (where h is the maximum height reached by the mass)
Since energy is conserved, we can set these two equations equal to each other:
0.5kx^2 = mgh
Solving for x, we get:
x = √(2mgh/k)
Plugging in the values given in the question, we get:
x = √(2*0.3*9.8*0.4/200) = 0.095m
Therefore, the spring will be stretched by 0.095m as the mass and spring rebound. It is important to note that this is the maximum distance the spring will stretch, as it will gradually decrease as the mass and spring oscillate.
1. What is spring energy?
Spring energy refers to the potential energy stored in a compressed or stretched spring. This energy is a result of the work done to either compress or stretch the spring, and can be released when the spring returns to its original shape.
2. How is spring energy calculated?
The amount of spring energy can be calculated using the formula: E = 1/2kx^2, where E is the energy in joules, k is the spring constant (measured in newtons per meter), and x is the displacement of the spring from its equilibrium position (measured in meters).
3. What factors affect the amount of spring energy?
The amount of spring energy is affected by the spring constant, the displacement of the spring, and the mass of any objects attached to the spring. The stiffer the spring (higher spring constant), the greater the energy stored. The larger the displacement and the mass attached, the more potential energy the spring will have.
4. How is spring energy used in everyday life?
Spring energy is used in a variety of everyday objects such as door hinges, mattresses, and trampolines. It is also used in various mechanical devices, such as shock absorbers in cars and pogo sticks, to store and release energy.
5. Can spring energy be converted into other forms of energy?
Yes, spring energy can be converted into other forms of energy such as kinetic energy, thermal energy, and electrical energy. For example, a mousetrap uses spring energy to snap shut and create kinetic energy to catch a mouse. This energy can also be converted into thermal energy due to friction from the movement of the trap.
