Homework Help: Spring Force, Distance Problem
  1. Nov 27, 2012 #1
    The spring in the figure has a spring constant of 1400N/m . It is compressed 16.0cm , then launches a 200g block. The horizontal surface is frictionless, but the block's coefficient of kinetic friction on the incline is 0.210.
    FIGURE ATTACHED
    What distance d does the block sail through the air?
    Correct answer: 13.4 m
    2. Relevant equations
    F(spring)=-kx
    F(friction)=μf*FN
    Work=Fdcos(θ)
    Work=(0.5mv22)-(0.5mv12)
    3. The attempt at a solution
    F(spring)=(-1400 N/m)(0.16 m)= 224 N
    F(friction)=(0.210)(cos(45))(0.2)(9.8)= 0.29 N
    224-0.29= 223.71
    Work=223.71d
    Work=(0.5)(0.2)(?)-(0.5)(0.2)(?)
    I think that I should be finding the work and then find distance by dividing by the force. However, I'm not sure how to find the two velocities.
  3. Nov 27, 2012 #2
    tiny-tim
    hi rocapp! :smile:
    you can't find d from work or energy, you'll need the usual projectile equations
    to find the initial speed (just before d), use the work-energy method that you have been using (with the block starting with zero speed), but use gravity also :wink:
