Homework Help: Spring, Pulley Problem Help.
  1. Nov 1, 2012 #1
    MG5
    A 3.8-kg sphere is suspended by a cord that passes over a 1.3-kg pulley of radius 3.5 cm. The cord is attached to a spring whose force constant is k = 86 N/m as in the figure below. Assume the pulley is a solid disk.
    (a) If the sphere is released from rest with the spring unstretched, what distance does the sphere fall through before stopping?
    The answer to this is .866 m. Not sure how to get it though.
    (b) Find the speed of the sphere after it has fallen 25 cm.
    Answer to this is 1.73 m/s. Not sure how to get this either.
    I'm not quite sure how to start this. I guess I'd use...
    1/2kx2 for the spring, mgh since the sphere has PE before falling, 1/2mv2 for final KE of the falling sphere. And I'd have to do something about the pulley. I guess KE=Iω2 since its rotating? Not sure about that. And its a sphere that is falling and the I for a sphere is I=2/5mr2. Dont know if thats needed for this problem. Any help would be great. Thanks.
  3. Nov 1, 2012 #2
    tiny-tim
    Hi MG5! :smile:
    same method you're using for (b), with final speed 0 for both the sphere and the pulley :wink:
    1/22, otherwise yes :smile:
    no, you only need moment of inertia if the sphere is rotating :wink:
  4. Nov 1, 2012 #3
    MG5
    Yeah I meant to add the 1/2 in there. Thanks for pointing that out. I'm gonna give it another shot and see how it goes.
  5. Nov 1, 2012 #4
    lewando
    For what its worth for (a), when the sphere loses the maximum PE, the spring will have gained maximum PE. Conveniently, at this time the pulley is not spinning. This does not help with (b) though.
  6. Nov 1, 2012 #5
    MG5
    Ok this is the equation I came up with. Doesnt seem right though.
    mghi=1/2mv2+1/2kx2
    I dont know what the height would be though
  7. Nov 1, 2012 #6
    tiny-tim
    is this (a) or (b)? :confused:
    if it's (a), v = 0; if it's (b), what about ω ?
  8. Nov 1, 2012 #7
    lewando
    As long as the cord does not stretch x and h will be related.
  9. Nov 1, 2012 #8
    MG5
    First I'm trying to figure out (a). Then I'll try to do (b)
    Well the 1/2mv2 was the final KE. If it was initial it would be zero. But yeah I just realized I dont have the velocity either. Too many unknowns
  10. Nov 1, 2012 #9
    tiny-tim
    but the final velocity is also zero :wink:
  11. Nov 1, 2012 #10
    MG5
    yeah I saw that but I still wasnt sure.
    So would it be something like mgh=1/2kx^2
  12. Nov 1, 2012 #11
    tiny-tim
    why??! :rolleyes:
    yup! :biggrin:
  13. Nov 1, 2012 #12
    MG5
    I thought it wasnt just because in like projectile motion problems when it asks how far something traveled and like where it hit the ground from its initial starting point the final velocity was never zero. I thought we usually needed that value to find x. But thats a completely different problem. Now I know.
    Only problem with that equation is I have no idea what the height is to put into mgh.
  14. Nov 1, 2012 #13
    arildno
    Dearly Missed
    Set up an energy equation.
    Remember that mgh, FOR THE PULLEY,is a constant until "Dovre falls"
    (Dovre is a mountain chain in my native country Norway!)
  15. Nov 1, 2012 #14
    tiny-tim
    same as x ! :smile:
  16. Nov 1, 2012 #15
    MG5
    but then theres two unknowns, one on each side of the equation. Sorry if I'm just really off with this. Hopefully you can bear with me.
  17. Nov 1, 2012 #16
    lewando
    No worries! x = h. x can be substituted for h and vice-versa. [edit-- sorry]
  18. Nov 1, 2012 #17
    MG5
    Yeah but still. It could be giraffe lol. Its still an unknown.
  19. Nov 1, 2012 #18
    lewando
    You have 2 equations and 2 unknowns.
    kx2/2= mgh
    x = h
    This is solvable.
    [edit-- I originally said x = y, I meant x = h]
  20. Nov 1, 2012 #19
    MG5
    Yeah it is. Sorry I'm just not used to having to unknowns. As usual, I was making it much harder than it was.
    I got it
    3.8kg(9.8)x=1/2(86N/m)x^2
    37.24x=43x^3
    Subtract 37.24, then do 43/37.24, and you get the answer .866. That was easy.
    Now the second part.
    Finding the speed after it has fallen .25 meters.
  21. Nov 1, 2012 #20
    lewando
    What?
    There should be no subtraction and no x3.
    Unless that's a typo, you got lucky on the math. Make sure you are clear on this before proceeding.
  22. Nov 1, 2012 #21
    MG5
    Yeah that was suppose to be x^2. and yeah I didnt subtract anything lol i dont know why I wrote that. I just ended up with 37.24=43x, divided, x =.866. I got it.
  23. Nov 1, 2012 #22
    lewando
    By now you should be thinking how to solve this with conservation of energy concepts. I need to clockout for the evening but I will leave you with this general outline:
    When the system first begins, all the energy is in the sphere in the form of PE. Since PE is relative to some reference point, I suggest you use the result from (a) to serve as your maximum and minimum (zero) PEsphere references.
    As the system begins moving, PEsphere is reduced, KEsphere starts increasing, PEspring starts increasing, and KEpulley starts increasing.
    As arildno suggested, set up an energy equation involving all these terms. Relate the terms that you do not know (KEpulley, and KEsphere) to v, which you will solve for.
  24. Nov 1, 2012 #23
    MG5
    Ok so something like 1/2mv^2 + 1/2kx^2 = 1/2Iw^2. not quite though but yeah ive been trying to set up the conservation equation and cancelling out the things i dont need
  25. Nov 2, 2012 #24
    tiny-tim
    (just got up :zzz:)
    show us what you've got :smile:
