1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Spring Questions
  1. Oct 19, 2014 #1
    There are two problems, but I think that they are similar:
    A toy gun shoots a projectile straight up. The maximum height reached by the projectile is H when the spring is compressed x cm. For the projectile to reach a height of 2H, the spring of the gun should be compressed how much?
    The bumper of a car is connected to the body by a spring of spring constant k. When the car hits a cement wall with a speed of 1.0 km/h, the spring compresses 1.0 cm. If the car hits a cement wall with a speed of 2.0 km/h, the spring will compress by how much? (answer in cm)
    2. Relevant equations
    The work of the spring is Ws = -.5*k*x^2
    The force of the spring is F=-kx
    3. The attempt at a solution
    Problem 1: If work is force * distance, then the equation of the work of the spring can be set equal to the equation for the force of the spring * the distance H:
    -k*x*H = -.5*k*x^2
    after some algebra, you get to this equation:
    H=1/2x
    So if you wanted to double H, you would also double x.
    So in terms of x, the spring should be compressed 2x cm. However, this is not the correct answer, but I think my reasoning is correct. Can somebody point out the flaw?
    Problem2:
    If -.5*k*x^2 = .5*m*v^2,
    you would plug in "2*v" for v because 2km/hr is double 1km/hr
    Thus, x would be 2 times the original x for 1km/hr, so the spring would compress 2cm.
    I'm not sure if this problem is correct, because the previous problem is incorrect so I'm not sure about spring problems.
  3. Oct 19, 2014 #2
    mfb
    2016 Award
    Staff: Mentor
    Where does the left side come from?
    And where did you take gravity into account?
    The projectile loses contact to the spring after the first x cm.
    The second solution is correct.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Spring Questions
  1. Spring Question (Replies: 5)
  2. Rocket Spring question (Replies: 4)
  3. Spring pull question (Replies: 1)
  4. Spring questions (Replies: 4)
Loading...
