I Spring within a spring
  1. Nov 30, 2016 #1
    So I am doing tensile testing on an elastic electrical lead for biomedical purposes. The lead is encapsulated in an elastic tubing. Now the lead acts like a weak spring itself (coiled wire).
    I'm curious, if there are two springs with different k constants "within" each-other (one inside the other) will it effect the Hooke's law equation? Or will the dominant k constant be the baseline?
  3. Nov 30, 2016 #2
    RUber
    If you have two springs with the same k embedded into each other, what would happen? I think since the density of the spring is changed, you would have a greater stiffness. Would you use 2k and just add the two? If the springs were separate and working together you could assume that they work together.
    Using
    ## F = k_1X_1 + k_2X_2 ##,
    you can see that if the displacement is the same, the effective k is the sum of the two.
    If the second is much weaker than the first, ignoring it will likely not induce a significant error.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Spring within a spring
  1. Spring pendulum (Replies: 1)
  2. Spring Pendulum (Replies: 1)
  3. Pulleys and spring (?) (Replies: 2)
  4. Spring Gun (Replies: 5)
Loading...
