SQL columns
  • Thread starter ponjavic
Isn't possible to delete and remove columns after a table has been created?
Rows works just fine but columns don't...
Answers and Replies
in MySQL, this is done with http://dev.mysql.com/doc/mysql/en/ALTER_TABLE.html [Broken]
Note that columns and rows in a database are very different things, so the fact that you can do something to a row doesn't automatically mean you should be able to do the same thing to a column.
Still, any good database should allow you to delete a column unless you've deliberately added constraints that would prevent it. But you have to modify the table to do that, usually with an ALTER TABLE statement.
You can, but its not considered a good thing to do, except possibly when prototyping. This is because you are altering your schema, which shouldn't happen. Would you want to alter the form of a data structure at runtime?
If your schema is wrong, why wouldn't you change it?
It is a DDL command and is language specific.
Related Threads on SQL columns
  • Last Post
  • Last Post
  • Last Post
  • Last Post
