SQL Help?
  1. Nov 12, 2006 #1
    I'm having trouble getting the following work. Can anyone help me?
    I have two tables that look like the following:
    Code (Text):
    Table 1                 Table 2
    A B                     A B C
    1 4                     1 4 6
    2 5
    3 6
    How do I join both of them such that the end result would be this?
    Code (Text):
    Result
    A B C
    1 4 6
    2 5 null
    3 6 null
    I tried to do the right, left, normal joins, and union, but I still cannot get it to show like the resulting table. Any help would be great, thanks.
  3. Nov 12, 2006 #2
    -Job-
    Try something like (tsql):
    Code (Text):
    SELECT A, B, NULL AS 'C' FROM Table1
    UNION ALL
    SELECT A, B, C FROM Table2
  4. Nov 12, 2006 #3
    Thanks for the reply. I just gave that a try and it did the following:
    Code (Text):
    Result
    A B C
    1 4
    2 5
    3 6
    1 4 6
    I'm using PSQL PostgresSQL to do this stuff. Should it be the same with your tsql code? Because I get the table above when doing your example.
  5. Nov 12, 2006 #4
    -Job-
    Sorry, i misread what you wanted to do. How about the following:
    Code (Text):
    SELECT t1.A, t1.B, t2.C
        FROM Table1 AS t1
        JOIN Table2 AS t2 ON (t1.A = t2.A AND t1.B = t2.B)
  6. Nov 12, 2006 #5
    -Job-
    Ok, the following worked for me:
    Code (Text):
        FROM Table1 AS t1
    UNION ALL
    SELECT t1.A, t1.B, NULL AS 'C'
        FROM Table1 AS t1
        JOIN Table2 AS t2 ON (NOT t1.A = t2.A)
  7. Nov 12, 2006 #6
    Thanks, that worked, but what do you need to add if there are duplicate entires in Table 1?
    ie.
    Code (Text):
    Table 1
    A B
    1 4
    1 4
    2 5
    3 6
    Using the latest query you wrote, I get the resulting table:
    Code (Text):
    Table 1
    A B C
    1 4 6
    2 5
    3 6
    One of the same 1 4 entry is removed. I tried taking out the NOT, but still the same result.
  8. Nov 12, 2006 #7
    -Job-
    That doesn't happen to me, it must be a PSQL implementation.
    Anyway, the following should work for you, even if it's not optimal:
    Code (Text):
    SELECT
    t1.A,
    t1.B,
    (SELECT t2.C FROM Table2 AS t2 WHERE t2.A = t1.A AND t2.B = t1.B) AS 'C'
    FROM Table1 AS t1
  9. Nov 12, 2006 #8
    That worked. Thanks a lot for your help!
  10. Nov 12, 2006 #9
    verty
    My first try would be:
    select t1.A, t1.B, t2.C
    from Table1 t1
    left outer join Table2 t2 on t1.A = t2.A and t1.B = t2.B
