Square circuit
thereddevils
438
In the circuit given (attached) , point S is earthed , what are the electrical potentials at point P , Q and R .
Kirchoff's second law .
The electric potential at point S is 0 . By applying Kirchoff's second law ,
I(2+3)=15-5
I=2A
i am not sure where to go from here .
Answers and Replies
Doc Al
Mentor
45,410
1,845
You found the current. In what direction does it flow? Use that to find the voltage drops across each resistor.
thereddevils
438
ok , the current is flowing in the clockwise direction . Could you elaborate a little further on the voltage calculation of each resistors ?
But the question is asking for the potential at points P,Q and R respectively . How is it related to the potential difference across the resistors .
Thanks !
Doc Al
Mentor
45,410
1,845
Good.
Sure. The voltage across each resistor is given by Ohm's law: ΔV = IR. To find the sign of the voltage across the resistor, you need to know the direction of the current. Hint: Does current across a resistor flow from lower to higher potential or from higher to lower?
To find the potential at any point with respect to some reference, just add up the voltage drops across each piece. Here your reference is point S, which is marked as ground and thus is at 0 Volts. To find the potential of point P, for example, you need to find ΔV from S to P. S to P contains a battery, so what's ΔV? To find the potential of point Q, you'll add up the voltage drops across S-P and P-Q. What's the voltage drop from P to Q across that 2 Ω resistor?
thereddevils
438
Good.
thanks ! Now , i understand this question better . Let me attempt again .
Since the emf of the 15 V battery > emf of 5V battery , the current will be flowing in the clockwise direction .
pd across sp would simply be -5V .
pd across 2 ohm resistor is 2/(2+3) x (5-15)=-4V so pd across SQ is -5-4=-9V
pd across 3 ohm resistor is 3/(2+3) x (5-15)=-6V so pd across SR is -15 V
Are my reasonings correct ?
Doc Al
Mentor
45,410
1,845
Perfecto!
Just for fun, realize that you can find the potential of a point (Q, say) by starting from S and going clockwise around the circuit or by going counter-clockwise. Do it both ways and check that you get the same answer.
thereddevils
438
Perfecto!
yay! Thanks ! Yeah , i have experimented with that
Suggested for: Square circuit
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
