Square Root of a Matrix
  • Thread starter SometimesY
Main Question or Discussion Point
Hey all,
I've run into a snag with research and it is partly related to taking the square root of a matrix. I've seen related stuff concerning matrices that can be diagonalized, however the 2x2 matrix in question is not diagonalizable. Can the square root of such a matrix be determined? If so, how?
Thanks!
Answers and Replies
SteamKing
Staff Emeritus
12,798
1,666
SometimesY: Boy, I would like to see a 2x2 matrix that cannot be diagonalized!
HallsofIvy
41,770
911
Here's one:
[tex]\begin{bmatrix}1 & 1 \\ 0 & 1\end{bmatrix}[/tex]
Happy?
If a 2 by 2 matrix cannot be diagonalized, it must have a single eigenvalue and it can be put into "Jordan Normal Form",
[tex]\begin{bmatrix}x & 1 \\ 0 & x\end{bmatrix}[/tex]
where "x" is that single eigenvalue.
Now, if
[tex]\begin{bmatrix}a & b \\ c & d \end{bmatrix}[/tex]
is a "square root" for that matrix, we must have
[tex]\begin{bmatrix}a & b \\ c & d \end{bmatrix}\begin{bmatrix}a & b \\ c & d \end{bmatrix}= \begin{bmatrix}a^2+ bc & ab+ bd \\ ac+ dc & bc+ d^2\end{bmatrix}= \begin{bmatrix}x & 1 \\ 0 & x\end{bmatrix}[/tex]
That is, we must have [itex]a^2+ bc= x[/itex], [itex]ab+ bd= 1[/itex], [itex]ac+ dc= 0[/itex], and [itex]bc+ d^2= x[/itex].
From [itex]ac+ dc= c(a+ d)= 0[/itex] we must have either c=0 or a+ d= 0. But a+ d= 0 cannot satisfy [itex]ab+ bd= b(a+ d)= 1[/itex] so we must have c= 0.
Then [itex]a^2+ bc= a^2= x[/itex] and [itex]bc+ d^2= d^2= x[/itex].
Since [itex]a^2= d^2= x[/itex] we must have either a= d or a= -d. If a= -d then ab+ db= b(a+d)= 0 so that ab+ db= 1 is impossible. If a= d, then ab+ db= 2ab= 1 so that b= 1/(2a). That is, the matrix
has two square roots:
[tex]\begin{bmatrix}\sqrt{x} & \frac{1}{2\sqrt{x}} \\ 0 & \sqrt{x}\end{bmatrix}[/tex]
and
[tex]\begin{bmatrix}-\sqrt{x} & -\frac{1}{2\sqrt{x}} \\ 0 & -\sqrt{x}\end{bmatrix}[/tex]
SteamKing
Staff Emeritus
12,798
1,666
Halls of Ivy: Nice try. But your example is a matrix which is already diagonalized. I understand a diagonal matrix to be one where the main diagonal has all non-zero entries and only zero entries above or below the main diagonal.
AlephZero
6,993
291
Sorry, but that is not the definition that everybody else uses.
The thing you described is a upper or lower triangular matrix. Upper and lower say which side of the diagonal has non-zero terms.
Thanks HallsofIvy! That's exactly what I was looking for. It means a lot!
HallsofIvy
41,770
911
Those are "upper triangular" and "lower triangular" matrices.
http://en.wikipedia.org/wiki/Triangular_matrix
"Diagonal" matrices, oddly enough, are those that are non-zero only on the main diagonal.
http://en.wikipedia.org/wiki/Diagonal_matrix
What text book or other place defines a "diagonal matrix" the way you say?
SteamKing
Staff Emeritus
12,798
1,666
I stand corrected.
Related Threads for: Square Root of a Matrix
  • Last Post
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
36K
  • Last Post
