Square roots of complex numbers
  1. Aug 8, 2012 #1
    Bacle2
    Re: An algebraic property of complex numbers
    Mod note: These posts are orginally from the thread: https://www.physicsforums.com/showthread.php?t=626545
    The square root is not defined everywhere, at least not as a function,
    but as a multifunction, since every complex number has two square roots. I mean, the
    expression z1/2 is ambiguous until you choose a branch.
    Sorry if you already are taking this into account; I am in nitpicking mode, but I
    shouldn't take it out on you :) .
  3. Aug 9, 2012 #2
    chiro
    Taking the square root of a number (even a complex one) is a function and is not multi-valued. I think you are confusing finding the roots of some expression with this and they are different.
    Also it is true that any complex number can be written in infinitely many ways (by adding 2npi to the argument where n is an integer), but this is not the same as the issues with finding roots since the square root is a function and only returns one result (all functions have to do this). In terms of the principal argument, the result is always unique.
    Your condition about not including 0 means that you can reverse r^1/2 to get r back and since this operation is a bijection, getting the inverse back with respect to the principle argument is also a bijection (and remember that r > 0 so we don't have any branch issues).
  4. Aug 9, 2012 #3
    Bacle2
    What do you mean square roots are not multifunctions? They are multifunctions even in
    the real case. In the complex case:
    The square root of re are:
    r1/2e(iθ/2) and
    r1/2ei(θ/2+∏) , by.e.g. DeMoivre's inequality:
    and the roots are ∏<2∏ appart, so they are not separated by different copies of the plane
    as, e.g., periodic functions of period ≥2∏.
  5. Aug 9, 2012 #4
    pwsnafu
    The square root of a non-negative real number is always non-negative. It is never multi-valued.
  6. Aug 9, 2012 #5
    Bacle2
    Well, I think this is a technical/language issue: by default, one often _defines_ the
    square root √x is defined by default to be the positive solution--when it exists, i.e.,
    when x>0 ( for 0, there is one solution). Maybe a more accurate way for me to
    phrase things is : when x is a positive number, there are two numbers whose square
    equals x. I don't know if the choice of the positive solution is just a convention, or if
    there is some other reason for this choice.
  7. Aug 9, 2012 #6
    chiro
    Finding roots is not the same as finding the function to some power: they are completely different things.
    Again, functions always by definition return one output: they have to.
    Root-finding is an entirely different thing and not to be confused with an actual function.
  8. Aug 9, 2012 #7
    Bacle2
    Yes, that is the precise point I am making, and this is why I'm making the distinction
    between multifunctions and functions. There are two potential candidates for
    a square root, and we select one. This is the whole reason Riemann surfaces exist;
    to turn expressions that are multifunctions when seen in the complex plane into
    functions when defined in Riemann surfaces.
  9. Aug 9, 2012 #8
    chiro
    No you have it confused: the square root of a complex number has all the properties of a function and thus it only produces one unique value.
    The roots of a variable is not the same as taking some nth root of a number: it is completely different.
    The function is mapping many things to one thing and that's why when you find the nth roots of a complex number, you get multiple answers because the function that produced them mapped all the inputs to one output.
    De-moivre's theorem with regard to finding roots is completely different than using a function mapping to take something from one set and map it to another.
    Don't confuse the two.
  10. Aug 9, 2012 #9
    Bacle2
    I do not believe, nor have I claimed that taking the nth root of a number is equivalent
    to the n-th root function.
    There is also the fact , re a function:
    If a function f maps n-to-1 ,as is the case with the n-th root, then , its inverse (inverse as a relation) maps 1-to-n
    and so this inverse cannot be a function-- unless its domain is restricted.
    I think you have misunderstood what I'm saying.
  11. Aug 9, 2012 #10
    Bacle2
    At any rate, I'll explain my layout better:
    1)We first define the square root of a (positive for now) number x , to be any number y with y^2=x. This is a 1-to-2
    relation. Similar applies to defining n-th root ( which exists for negative numbers when
    n is odd, but let's restrict to positive for now ).
    2) In order to turn above relation into a function, we select _exactly_ one of the
    n-th roots of the number. We define the n-th root _function_ evaluated at
    x, to be the specific number y above that satisfies y^n =n . We could have
    defined an n-th root function by selecting _precisely_ one other solution to y^n=x.
    3) In order to do the selection in 2) , we must restrict the domain , so we can remove
    all (n-1) solutions to y^n=x . Otherwise, the relation--a function too, in this case --
    will not have an inverse:
    If the relation allows n-to-1 , say , the pairs (x1,y),(x2,y),...,(xn,y) are in the
    relation, then the pairs : (y,x1), (y,x2),...,(y,xn) are , by definition, part of the
    inverse relation --which cannot be a function. z^n is n-to-1 , meaning that its
    inverse --as a relation-- is 1-to-n , since if the pairs {(z1,f(z)),(z2,f(z),...(zn,f(z))}
    ={(z1,y),..,(zn,y)} are in the relation created by z^n , so that the collection of pairs:
    { (y,z1),(y,z2),..,(y,zn)} are in the inverse relation. This inverse relation has to be
    restricted to turn it into a function, because we do not allow two different pairs (y,zi),
    (y,zj) in a function.
    4) Riemann surfaces are used to help avoid n-to-1 relations. This is why many n-to-1 functions
    are defined in Riemann surfaces , instead of in the complex plane. There are even examples of
    oo-to-1 functions, like logz (note I'm not using caps here , but lower-case instead.) , which are represented
    by a "parking lot" Riemann sphere. We then _select_ a branch of logz ; usually the main branch Logz
    to turn a 1-to-oo relation into a function.
    If you disagree with this , then please explain to me why we define branches of functions in the complex plane.
  12. Aug 9, 2012 #11
    jgens
    Just my 2 cents here:
    1. In the real case when you see a square-root sign it almost always means the principal square-root.
    2. In the complex case things get more complicated. The issue now is that while we can define a square-root function on the whole complex plane, there are several ways we can naturally consider doing this and none of these ways make the square-root function continuous. For example
    [tex]r\exp(i\psi) \mapsto \sqrt{r}\exp(\frac{i\psi}{2}) \;\;\;:\;\;\; -\pi < \psi \leq \pi[/tex]
    [tex]r\exp(i\theta) \mapsto \sqrt{r}\exp(\frac{i\theta}{2}) \;\;\;:\;\;\; 0 < \theta \leq 2\pi[/tex]
    Both of these are defined by the same formula, but they define a different function depending on which values of [itex]\psi[/itex] and [itex]\theta[/itex] we allow. It is also worth noting that the first function is discontinuous along the negative real axis while the second function is discontinuous along the positive real axis. To get around this, these functions are often defined without the discontinuous parts. This is one reason why choosing branches in the complex case becomes so important, especially since while there is a principal branch for the square-root in the complex numbers, it is fairly common to use non-principal branches in the complex case (unlike the real case).
  13. Aug 9, 2012 #12
    I think mathematics would benefit tremendously if students were taught early on that square root and other inverse functions are indeed multivalued. That is I do not feel we do justice to math by viewing [itex]\sqrt{z}[/itex] as a single-valued entity. Granted, when mapped over it's normal Riemann surface, it is single-valued, but it still has two values for each value of z except at the branch-point. So what happens now is that we don't and when all of a sudden the student finds himself in Complex Variable or Analysis, he finds the entire concept of multi-valued functions, branch-cuts, branches, Riemann surfaces, and worst of all, contour integrals over them, a formidable undertaking, gets discouraged, and Mathematics looses another potential genius.
  14. Aug 9, 2012 #13
    jgens
    I think it depends. While it may make the complex variable theory a bit harder (and I am not convinced that it does), it certainly simplifies the real variable theory to consider only principal branches.
  15. Aug 9, 2012 #14
    chiro
    We are talking about the set of complex numbers aren't we?
    I have a question: you guys are talking about sending reitheta to r1/2ei/2*theta
    Now cos(1/2theta) and sin(1/2theta) are both continuous and differentiable with respect to theta. SQRT(r) on the other hand is also since r > 0.
    All of these representations: SQRT(r), cos(theta/2) and sin(theta/2) all produce single answers. How is this not a function?
  16. Aug 9, 2012 #15
    jgens
    It is a function. But do you mind telling me which of the functions below you are talking about?
  17. Aug 9, 2012 #16
    chiro
    The bottom one.
  18. Aug 10, 2012 #17
    jgens
    The bottom one is actually the non-principal branch. The point I am hoping to get across is that, unlike in the real variable case, there is not a nice canonical choice regarding which branch to work with in the complex case. This was Bacle2s contention about the expression z1/2 being ambiguous without specifying the branch.
    Edit: To be clear, I actually disagree that the expression is ambiguous since I would take z1/2 to mean any square-root of z in the given context, but I do agree that the expression would be ambiguous if the OP were talking about functions instead of identities for the reasons expressed above.
  19. Aug 10, 2012 #18
    rbj
    that is simply not correct.
    doesn't matter if it's real or complex, if it ain't zero, there are always two square roots to every number, and they are negatives of each other.
  20. Aug 10, 2012 #19
    chiro
    I'm talking about obtaining just a complex number in the cartesian form by taking the square root of it: you can convert to polar form or whatever, but as long as it's non-zero it exists and is unique.
    I am aware of the different branches, but the evaluation of the final quantity will always be unique: all valid functions are.
  21. Aug 10, 2012 #20
    pwsnafu
    There are indeed two square roots, but I used the definite article for a reason. Only the positive one is called "the square root". The square root function on positives is indeed a function.
