Square roots of large numbers
  1. Dec 1, 2011 #1
    I stumbled upon a math question, at the glance of it, seemed easy.
    One is supposed to find the exact value of this square root:
    √30*31*32*33+1
    They are all under the square root operator and Fundamental BEDMAS/BIDMAS applies of course.
    The trick here is when the condition states that one cannot use a calculator.
    Any suggestions, anyone?
  3. Dec 1, 2011 #2
    jgens
    I do not know any tricks to actually solve this, but you can get a fairly good estimate using basic calculus. In particular, note that 312 < (30*31*32*33 + 1)1/2 < 322. We can model √ around 314 linearly by the function defined by L(x) = 312 + (2*312)-1(x-314). Take x = 31.54 as an initial guess and we get something like L(x) ≈ 992. I think that actual answer is 991, so this gets you a pretty good estimate and all of the calculations are manageable.
    I am sure someone else knows a nice method to tackle this problem though, so I would like to see that as well.
  4. Dec 1, 2011 #3
    D H
    Staff Emeritus
    You are looking for some number [itex]n=\sqrt{30*31*32*33+1}[/itex]. Squaring both sides to get rid of the radical yields [itex]n^2=30*31*32*33+1[/itex]. Writing 31, 32, and 33 as 30+1, 30+2, and 30+3 yields [itex]n^2=30^4+6*30^3+11*30^2+6*30+1[/itex]. This suggests writing n in a similar form: [itex]n=30^2+a*30+b[/itex]. Squaring yields [itex]n^2 = 30^4+2a*30^3+(a^2+2b)*30^2+2ab*30+b^2[/itex]. Equating the expansion of 30*31*32*33+1 with this readily yields a=3, b=1, and thus n=991.
  5. Dec 1, 2011 #4
    D H
    Staff Emeritus
    This is another approach. The answer has to be fairly close to 992. The word "exact" in the question indicates the number has to be an integer. The last digit of this number must be either one or nine, and the answer certainly isn't 999 or 981. The only viable choices are 991 and 989. Just square each (not hard) and compare to 30*31*32*33+1 (which you will have to expand for this approach). Since the original guess was 992, starting with 991 will eliminate the need to try 989 as the second choice since the answer is indeed 991.
  6. Dec 1, 2011 #5
    jgens
    That is a nice solution! Much better than my thoughts on the problem.
  7. Dec 1, 2011 #6
    Thanks for the quick replies ! Really appreciate it !
    I was thinking along the lines of having a number n which would be that exact value but as I worked it through I got stuck, where you presented the n = 30^2 + 30a + b part was where I got stuck, but your explanation was really good so thanks again.
  8. Dec 2, 2011 #7
    lurflurf
    30*31*32*33+1=x^2
    since
    31*32-30*33=(x+1)-(x-1)
    and
    30*31*32*33=(x+1)*(x-1)
    we can see that
    30*33=x-1
    31*32=x+1
    and x is easy to find
Loading...
