Square Wave Generator
  1. Nov 16, 2007 #1
    im working on my senior design project and was looking for some help in designing a square wave generator that outputs a 32khz, 5Vpp square wave. i found a site that shows a circuit
    http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/square.html
    but when i connect the circuit for some reason it doesnt work.
    im using a lm339 quad comparator
    R=14kohm
    C=0.001uf
    r1=r2=100kohm
    5V supply
    please help
  3. Nov 16, 2007 #2
    i tried this before and it works. did mine with +-5V. i think you were using +vcc and gnd. the square isnt really square, a bit like trapezoidal, so i'd recommend putting some sort of trigger or inverter to get a nice square wave
    also make sure your lm339 has the bandwidth to do what you want to do
  4. Nov 16, 2007 #3
    berkeman
    Staff: Mentor
    I'd just use a 4060 CMOS oscillator/counter with a 32kHz watch crystal:
    http://www.national.com/ds/CD/CD4020BC.pdf [Broken]
  5. Nov 16, 2007 #4
    dlgoff
    Could you explain the reason for the variable 39pF cap on the xtal? I'm thinking it's for tweeking the freq. but not sure.
    Thanks
  6. Nov 16, 2007 #5
    berkeman
    Staff: Mentor
    Interesting, I didn't even notice that variable cap in the datasheet. It would allow you to bend/tweak the oscillation frequency as a fine-tune, like in a watch or clock. That 32.768kHz crystal (note the binary number, so it divides down to exactly 1 second with a ripple counter) is used in many time-keeping devices. Maybe the cheaper ones need a little fine tuning, or maybe the 200ppm typical spec for many crystals is not accurate enough for clocks.
    Let's see, +200ppm is 1.000200, so at the end of 60 minutes, your watch would read 0.7 seconds fast. At the end of a day, you would show 17 seconds fast, which is probably why they add the variable cap for watch/clock applications. Interesting.
  7. Nov 16, 2007 #6
    Averagesupernova
    Most crystal oscillators need a loading cap.
  8. Nov 18, 2007 #7
    dlgoff
    When I was a youngster, an old ham showed me how to take a crystal (the ones that have a small removable plate) and use a lead pencil on the crystals surface (an erase as needed) to tweek the frequency. Ever heard of that?
  9. Nov 18, 2007 #8
    try a 555 IC in astable mode....
