Square Wave Generator
  • Thread starter SwissApe
Greetings,
Sorry to bother you with such a trivial question, but I'm looking for a high frequency (>500 MHz) 2 channels square wave generator.
Do you know any material (not too expensive if possible) that would match these specifications?
Many thanks!
Answers and Replies
f95toli
822
Can you be a bit more specific?
Do you mean a generator with a 500 MHz analog bandwidth OR a generator that can produce a 50-50 square wave with a 1/500e6 s period?
In either case it sounds like you are asking about something called a pulse pattern generator. You can buy them from e.g. Agilent or Anritsu.
The price will probably be somewhere in the range $10 000-$30 000.
berkeman
Mentor
62,548
13,357
Greetings,
Many thanks!
500MHz 50 Ohm signal generators are available, but I don't know about the square wave part. What are you intending to use it for? 500MHz square waves exist on high-speed digital integrated circuits, but are not generally driven off-chip.
i was going to suggest DDS but doubt there's any chip out there to work with
f95toli is right, a real 2 channel square wave generator capable of 500Mhz is going to be pretty expensive.
But I'm guessing that you're interested in making something?
DDS - (Direct Digital Synthesis) chips are interesting. Analog Devices makes some but I'm not sure if you can get 500Mhz output from these.
Look up "astable multi-vibrator" circuits. Depends on your purpose, of course, but a simple circuit might be good enough.
I don't know if this would satisfy your needs, but couldn't you take a 500mHz sine wave and put two diodes in anti-parallel across the output, amplify the voltage if necessary, then use zener diodes to help eliminate the non-horizontal parts of the wave?
The problem comes if you need to alter the duty cycle of one part of the wave.
Many thanks for all your answers, I'll see what I can find in commercial pulse generators... I'm afraid I'm not good enough to make such a device on my own.
Related Threads on Square Wave Generator
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
