SR and QED: how?
nitin_zilch
42
SR and QED: how??????
how the particle moving at a speed near to that of light interact to it's surrounding,considering the very fact of it's time dilation?
what i mean to ask probably is that will it b possible for this particle to create another one from it's energy and still manage to throw the created particle with a speed again comparable to that of light?
Answers and Replies
tiny-tim
25,836
255
hi nitin_zilch! :smile:
if it's going through a vacuum, it will be exactly as if it's stationary (that's relativity) …
if it's going through a stationary medium (like air), it'll lose speed very fast :wink:
(i don't understand why you thought it might "create another one" :confused:)
nitin_zilch
42
if particle is travelling in any medium, won't it interact???????
if it does how????
and if it doesn't why not??
u can consider a proton inside nucleus and then apply the same question to it
nitin_zilch
42
can u explain proton-neutron interaction inside nucleus considering time dilation???
tiny-tim
tiny-tim
25,836
255
if it does how????
it will collide with the particles in the medium
that would be through the strong nuclear interaction
it has nothing to do with time dilation
Dale
Mentor
Insights Author
2021 Award
32,946
10,196
Are you thinking of something like the decay of a muon into an electron, an electron-antineutrino, and a muon-neutrino? If so, can you re-cast your question in terms of that reaction? If not, can you give a concrete example for your question?
Also, as tiny-tim mentioned the proton-neutron interaction is via the strong force and muon decay is via the weak force, so neither are really relevant to the thread title on QED.
nitin_zilch
42
the question is for all
isn't collision also a way of interaction??
nitin_zilch
42
tiny tim
protons inside nucleus are moving at very high velocity,will at that speed time dilation occurs with it's simultaneous strong interaction?
tiny-tim
25,836
255
the time dilation is negligible
even if it was large, it would still have no effect on the strong nuclear interaction
John232
249
Electrons in the atom travel close to the speed of light and they can emmit and absorb photons makeing them change energy levels. The photon comeing from them always travel at the speed of light if in a vacuum.
The electron has mass and can eject photons at a higher velocity than it is traveling.
Electrons and positrons can combine to create neutrons. These particles are said to decay at random times in their history with unceairtainty as if they decayed or didn't decay at the same time until they are observed and the wave fuction collaspes. But, I am still trying to figure that one out for myself. Relativity isn't that combatable with QM, so I don't think you will get a real answer.
tiny-tim
25,836
255
not in my lifetime! :redface:
John232
249
John232
249
Electrons and positron would annhiliate each other into photons.
Dale
Mentor
Insights Author
2021 Award
32,946
10,196
Yes. So is your question about how SR handles collisions? In SR collisions are governed by the conservation of the 4-momentum.
nitin_zilch
42
which of the following strong or weak or electromagnetic interaction willl have particle exchange rate high to manifest their effect?
Dale
Mentor
Insights Author
2021 Award
32,946
10,196
EM is fine for that. The effects of the exchange of photons is measurable.
nitin_zilch
42
dalespam
and why's that?...
why not strong or weak?....
also then tell the factor that makes strong interaction as so.....
is it so bcoz of exchange of heavy particles??
nitin_zilch
42
dalespam
is that only the exchange of heavy particles manifest as strong?
Dale
Mentor
Insights Author
2021 Award
32,946
10,196
I just said that the effects of photon exchange are measurable, I didn't say that the effects of exchange of W, Z, or gluons were not measurable. The EM force is easier, so let's just stick with that and not complicate things unnecessarily.
Can you ask your question in a very explicit manner using a concrete example of the exchange of a photon? We are now on the second page and still have no idea what you are asking. Try to be very clear.
nitin_zilch
42
ok ............dalespam
i started all this to check the interaction process of a particle when it has undergone enough time dilation,i still doesn't have that answer,i think i need to check the biological process of aging for humans and then will think upon the series of events that could b responsible for that .......
Dale
Mentor
Insights Author
2021 Award
32,946
10,196
Of course you still don't have that answer, we still don't know what the question is. Please be clear and specific, use a concrete example. What do you mean by "check the interaction process", and which particles are you considering, and what do you mean by "enough time dilation"?
Your question is so vague that it is impossible to answer. You must put some effort into communicating clearly.
nitin_zilch
42
dalespam
her's the question that may give me my answer and will clarify u the context.......................
is there a biological process defining time dilation?if yes what's it
tiny-tim
25,836
255
no of course not :rofl:
Dale
Mentor
Insights Author
2021 Award
32,946
10,196
How do you think that this clarifies in any way what you mean by "check the interaction process" and "enough time dilation"? This seems entirely unrelated to all of your previous questions.
As tiny-tim mentioned, time dilation is defined in terms of the Lorentz transform, not anything biological. However, all biological processes would be affected by time dilation. This includes heart beats, respiration, diurnal rhythms, healing times, life expectancy, gestation period, reflex times, glomerular filtration rates, etc.
Suggested for: SR and QED: how?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
