Stability of a linear system
Determine the stability of the following linear system
[itex]y(n) = 0.5x(n) +100x(n-2) - 20x(n-10)[/itex]
[itex]x(n) = 0.5\delta(n) [/itex]
[itex]S=\sum^{\infty}_{k=0}\left| h(k)\right|[/itex]
[itex]Z \left\{ 0.5x(n) +100x(n-2) - 20x(n-10) \right\} [/itex]
[itex] Z \left\{y(n) \right\} = \frac{xz}{2(z-1)^2}+100x(\frac{z}{(z-1)^2}-\frac{2z}{(z-1)})-(\frac{20x}{(z-1)^2}-\frac{10z}{(z-1)}) [/itex]
[itex] \frac{80.5xz}{(z-1)^2}[/itex]
Now at this point we were told that there should be a polynomial in the numerator... did I go about this all wrong? Any recommend reading would be helpful as I have exhausted Google searching for a similar problem.
My original approach was simply to take the geometric series and use each coefficient from this equation if the formula [itex]\sum\frac{1}{1-a}[/itex]
My result was [itex] \approx -.47 [/itex] which I though would be marginally stable as it is between -1 and 1.
Answers and Replies
69
I don't know what you did, but typically one does not consider a specific input when determining the stability of a system; rather, one determines if the system is BIBO stable (bounded output for all bounded inputs).
Anyway, a reasonable approach is to apply the Z-transform to the equation for y[n] to get an equation for Z{y[n]} in terms of Z{x[n]} using the "time shifting" property. Then factor out Z{x[n]} from each of the terms.
To get the transfer function, divide by Z{x[n]}.
You may manipulate both numerator and denominator to get polynomials for each. If you have a number of terms with different denominators added, write them in terms of a common denominator. If the numerator or denominator have negative powers of z, mutliply the numerator and denominator by a term with a corresponding positive power of z. Similiarly, if something such as 1/(1 + z) appears in the denominator, multiply both numerator and denominator by (1 + z).
I had a feeling this was a strange question which doesn't help since I don't fully understand how to obtain transfer functions in the first place.
So applying the time shift
[itex]0.5X(n) + z^{-2}100X(z) -20z^{-10}(z)[/itex]
Collect the [itex]X(z)[/itex]'s This transform is from the time shift right?
[itex]X(z)= 0.5 + \frac{100}{z^{2}} - \frac{20}{z^{10}}[/itex]
So from here I could just manipulate the numerator and denominator to get whatever it is I need, yes? Now dividing by [itex]Z\left\{x[n]\right\}[/itex] I don't understand what value that would be in this case.
The time shift was the key for me! Thank you so much for your time.
69
This is wrong. It should be something like:
[itex]Y(z)= \left(0.5 + \frac{100}{z^{2}} - \frac{20}{z^{10}}\right)X(z)[/itex]
...I don't fully understand how to obtain transfer functions in the first place...Now dividing by [itex]Z\left\{x[n]\right\}[/itex] I don't understand what value that would be in this case.
This is a transfer function:
[itex]\frac{Y(z)}{X(z)}= \left(0.5 + \frac{100}{z^{2}} - \frac{20}{z^{10}}\right)[/itex]
Ah, so it has a transfer function of one! I didn't think that it would be that easy. This also means that is stable (poles at zero) so I think we are all set. Thanks again!
69
No, the system's transfer function is
[itex]\left(0.5 + \frac{100}{z^{2}} - \frac{20}{z^{10}}\right)[/itex]
Related Threads on Stability of a linear system
  • Last Post
  • Last Post
