• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Stability of object
  • Thread starter foo9008
1. Homework Statement
is it necessary to find the meta center for this question ? the formula of meta center is I /Vd , the I ( moemtn of inertia ) for rectangle is (ab^3) / 12 , but what is a ? what is b ? i'm confused now
2. Homework Equations
3. The Attempt at a Solution
ρ
gVsubmerged = weight(579N)
1025(9.81)Vsubmerged = weight(579N)
Vsubmerged = 0.058m^3
0.058m^3 = (1.2x0.9x hsubmerged)
hsubmerged =0.054m
center of buoyancy = 0.054/2 = 0.027m
metacenter = I / Vd = [(ab^3) / 12 ] /Vd
haruspex
Insights Author
2018 Award
31,682
4,677
For a rectangle measuring a by b, the second moment of area about an axis through the mid points of the sides of length b is ##\frac 1{12}ab^3##.
678
what is the value of a and b ? is the second moment about x -axis(Ixx) , right ? IMO , a is 0.9m , b is 1.2m , am i correct ?
haruspex
Insights Author
2018 Award
31,682
4,677
In principle, you should consider each axis as a potential axis for tipping. However, it is obvious that one of ab3, a3b is the larger. Which gives the greater danger of tipping, the larger or the smaller?
678
how to know which axis is more danger of tipping ?
the hydrostatic pressure act on the top and the bottom surface of the object , so i am consdiering the moment about x of tipping
haruspex
Insights Author
2018 Award
31,682
4,677
haruspex
Insights Author
2018 Award
31,682
4,677
in the link , it shows that the high metacenter of object enable the object to have higher stability against overturning, so the low metecanter of the object less stable , right ?
Yes.
To get a low metacentre, does "I" need to be large or small? If a>b, which of ab3 and a3b will give that less stable i?
678
Yes.
to get low metacenter , the I has to be small. since the water pressure act on the bottom of the box , the b is 1.2m , a is 0.9m , am i right ?
haruspex
Insights Author
2018 Award
31,682
4,677
It depends how you are defining a and b. Is that using the a3b form or the ab3 form?
678
Does a=.9, b=1.2 give a lower I than the other way around?
a=1.2 , b = 0.3 , i would get lower metacenter , but the formula is yp = yc + Ixx / (ycA) , Ixx is the second moment of inertia about x-axis . Ir cant be changed , right ?
haruspex
Insights Author
2018 Award
31,682
4,677
The object in question could tip about either of two axes. If you fix one direction as x and apply that formula you will only be considering one axis of tipping.
678
why not 3 axes? since the object is 3d ( as shown in the diagram )
678
for a = 1.2 , b = 0.3 , i will get metacenter = 1.25m , but , which value to choose ? 1.25m or 2.22m( a = 0.3, b = 1.2 ) ?
if metacenter = 1.25m or 2.22m , G located at 0.86m +0.3m =1.16 m , object is stable
haruspex
Insights Author
2018 Award
31,682
4,677
Yes, it's 3D, and you are right that in principle it could tip over any axis. But it is fairly obvious that the most likely tip is about the natural axes. Feel free to analyse the general case.:wink:
To check for stability, consider the worst case, i.e. the least metacentric height.
The metacentric height you calculated, 1.25m, is the height from the centre of buoyancy, not from the base.
But that only makes it even more stable than you concluded.
678
i thought when we consider the center of pressure , we only need to consider the Ixx ( second moment of inertia about x -axis) , y -axis is the vertical axis ..... this is the first question i ever encountered that we need to find the second moment of inertia about 2 axes
678
Why do we wanna consider 2 axes for rotation of object?
Normally we consider only 1 axis of rotation of object, right?
SteamKing
Staff Emeritus
12,794
1,665
You're getting confused here.
We're talking about the stability of this platform. The center of pressure, etc. has no bearing on this analysis.
The location of the metacenter M depends on the inertia of the waterplane cut by the hull of the platform. Using b = 0.3 would make no sense, since this dimension represents the depth of the platform's hull.
The Ixx used in the equation for yp represents something else and is not applicable here.
For the stability of this platform, BM = I / V, but I can be calculated about an axis which either runs parallel to the length of the platform or parallel to the breadth of the platform, which ever choice leads to the least value of I. V = volume of displacement and remains the same in any event.
Want to reply to this thread?
"Stability of object" You must log in or register to reply here.
Related Threads for: Stability of object
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
