Stability of Orbits
  1. May 7, 2012 #1
    So I saw a video on youtube: http://youtu.be/uhS8K4gFu4s
    And so I thought I'd try to understand the whole stable orbit thing.
    So first you have a simple energy equation of E = K + U.
    K = (1/2)mv^2 (kinetic energy)
    U = -GMm/r^2 (gravitational energy)
    r = radius of orbit
    v = velocity of orbiting object
    M = mass of center object
    m = mass of orbiting object
    And we want it to be a stable orbit in the first place, so we have:
    v=sqrt(GM/r)
    Now, let's say we slightly bump the object in orbit. So r -> r + s, where s is much less than r.
    (also w is much less than v)
    So we can adjust the stable orbit equation:
    v=sqrt(GM/r)
    v+w = sqrt(GM/(r+s))
    approximate for small distances:
    v+w = sqrt(GM/r)(1-s/(2r))
    So then, you can subtract the original equation out and have:
    w = -sqrt(GM/r)s/(2r)
    This makes sense directionally, if you bump the orbiting object inwards, the velocity with increase.
    So now, back to the energy equation: E = K + U
    Since it's a stable orbit being bumped only slightly, you expect it to be able to eventually return to the same state, so E can't change.
    So initially you have:
    E = (1/2)mv^2 - GMm/r^2
    Then apply the bump:
    E' = ((1/2)mv^2 )(1+2w/v) - (GMm/r^2 )(1-s/r)
    This then reduces to the form:
    E' = E + mvw + (GMm/r^2 )s
    Since E' must equal E, the two extra terms should add to zero:
    E' = E + (mv)sqrt(GM/r)(-s/(2r)) + (GMm/r^2 )s
    E' = E + (-1/2)(GMm/r^2 )s + (GMm/r^2 )s
    So I am doing something wrong. I have a missing factor of two somewhere, but I don't know why.
    If you guys can help, it will be appreciated. Thanks.
  3. May 8, 2012 #2
    K^2
    Stable orbit need not be circular. So if you bump it a little, it can become slightly elliptic and v=sqrt(GM/r) no longer holds. I think that's where things go wrong with your derivation.
    Best check of orbit stability is looking at effective potential.
