Stack of 6 cards probability
I am confused. That's why I was trying to find the probability by the same logic which I used to count the number of favorable outcomes.Can you please explain why my logic is wrong.
UrbanXrisis
1,196
In a stack of 6 cards, each card is labled with a different integer 0 through 5. If two cards are selected at random without replacement, what is the probability that their sum will be 3?
here's what I did... 0 1 2 3 4 5
to get either a 0,1,2, or 3 there is a 4/6 chance
after, there is a 1/5 chance to the the card that will add up to 3.
so...is the answer (4/6+1/5)=13/15?
I know that it's wrong but I'm not sure how to solve it
thanks,
Urban
There are 4 ways to choose two cards that sum to 3 ({1,2}, {2,1}, {0,3}, and {3,0}) and 6 x 5 = 30 ways to choose two cards. So, the probability is:
4/30 = 2/15
Your approach was also correct, but you should have multiplied the probabilities, not added them. It should be clear that adding doesn't make sense. Let's say you had 2 coins and are asked the probability that they're both heads. Adding gives you 1/2 + 1/2 = 1. Obviously that's wrong. Try it with 3 coins, you get a probability of 3/2, now that's obviously wrong. Now why should you multiply? Well, basically, you start off with some event, and you know the first part of the event only happens 4 out of 6 times. Now, even in the case where the first part goes right, the second part only goes right 1 out of 5 times. So, starting with 4 out of 6, only one fifth of those 4 will actually be any good. Hopefully you can see why you have to multiply (it seems kind of tough to put into words).
Let n = 6 = the number of cards in the stack.
Let r = 2 = the number of cards pulled.
Let N = the number of ways in which to pull two cards.
Let N(A) = the number of ways in which to pull two cards whose sum is 3.
[tex]N = C^{6}_{2} = \frac{6!}{2! 4!} = 15[/tex]
We've already established that N(A) = 4 by listing out the ways.
So [tex]P(A) = \frac{N(A)}{N} = \frac{4}{15}[/tex]
This assumes order doesn't matter.
If order didn't matter, the list would have 2 elements, not four.
AKG's analysis is correct.
We have six card,
1-card 2-card 3-card 4-card 5-card 6-card
0 1 2 3 4 5
+ 0 1 2 3 4 5
0 0 1 2 3 4 5
1 1 2 3 4 5 6
2 2 3 4 5 6 7
3 3 4 5 6 7 8 The experment have 25 out comes. But the event that
4 4 5 6 7 8 9 sum of two selected card is 3 will be 4 .
5 5 6 7 8 9 10 so probablity=event/outcome = 4/25
Didd said:
We have six card,
0 1 2 3 4 5
+ 0 1 2 3 4 5
0 0 1 2 3 4 5
1 1 2 3 4 5 6
2 2 3 4 5 6 7
Didd, I think you mean to say 6*6 = 36 outcomes (not 25).
Anyway, this is wrong because you are forgetting that once the first card is picked out, it is not replaced. So the first card can be picked in 6 ways, but the second card can be picked in only 5 ways. So there are 30 outcomes.
loseyourname, not only does your approach assume that order does not matter (in one part and not the other), it more importantly neglects non-replacement.
Gokul43201 , you are right! What am I thinking.
I was tricked by my silly reasoning. Thank you for catching that.
Well, it doesn't have to for the calculation to work.
That is, if I am consistent with the approach. Crap.
1. What is the probability of drawing 3 cards from a deck of 6 and getting all 6 cards in a stack?
The probability of drawing 3 cards from a deck of 6 and getting all 6 cards in a stack is 1/20 or 0.05. This is because there are 20 possible ways to arrange the stack of 6 cards (6! = 720 total combinations), but only 1 of those combinations will result in all 6 cards being in a stack.
2. If I have a stack of 6 cards, what are the chances of drawing the top 3 cards in order?
The chances of drawing the top 3 cards in order from a stack of 6 cards is 1/120 or 0.0083. This is because there are 120 possible ways to arrange the top 3 cards (3! = 6 total combinations), but only 1 of those combinations will result in them being in the correct order.
3. Is it more likely to draw a stack of 6 cards or a stack of 7 cards from a deck of 52 cards?
It is more likely to draw a stack of 7 cards from a deck of 52 cards. This is because there are more possible combinations for a stack of 7 cards (52 choose 7 = 133,784,560 total combinations) compared to a stack of 6 cards (52 choose 6 = 20,358,520 total combinations).
4. What is the probability of drawing a stack of 6 cards from a shuffled deck of 52 cards?
The probability of drawing a stack of 6 cards from a shuffled deck of 52 cards is 1 in 20,358,520 or approximately 0.0000000491. This is because there are 20,358,520 possible combinations for a stack of 6 cards out of a total of 52! possible combinations when shuffling a deck of 52 cards.
5. How does the number of cards in a stack affect the probability of drawing that stack from a deck of cards?
The more cards in a stack, the lower the probability of drawing that stack from a deck of cards. This is because as the number of cards in a stack increases, the number of possible combinations also increases, making it less likely to draw a specific stack compared to a smaller stack with fewer possible combinations.
  • Nuclear Engineering
