Standard nozzle thickness?
  1. Oct 24, 2015 #1
    If I'm looking for standard sizes of nozzle thickness.
    2. Relevant equations
    3. The attempt at a solution
    Should I be searching for the standard thickness of plates that are used to form the nozzle?
  3. Oct 24, 2015 #2
    SteamKing
    Staff Emeritus
    What kind of nozzle?
  4. Oct 24, 2015 #3
    it says " 4”-600# flanged" pipe
  5. Oct 24, 2015 #4
    Nidum
    (1) What is background to this question ?
    (2) Any pictures, drawings or links to manufacturers website that you can post ?
  6. Oct 24, 2015 #5
  7. Oct 24, 2015 #6
    SteamKing
    Staff Emeritus
    The specification talks about using 4" pipe and 6" pipe for "nozzles", but provides no other details.
    Usually, a drawing accompanies such a specification to provide the necessary details from which a cost estimate can be prepared.
    Both pipe sizes are given as Schedule 80, the wall thickness of which can be obtained from a standard pipe size chart:
    http://www.engineersedge.com/pipe_schedules.htm
  8. Oct 25, 2015 #7
    thanks, I also have a question about the shell design. I have an equation for the minimum required shell thickness
    ##\frac{P(R_{design}+corrosion)}{SE-0.6P}##
    but I'm not given R_design. should I guess an R_design? what should I look at to check if the guess is a good estimate?
  9. Oct 25, 2015 #8
    Nidum
    This is a pressure vessel so you will need to design shell , nozzles and other components to appropriate ASME codes .
