- #1
Fantastic Fox
- 24
- 0
Has anyone got a link to manufacturers catalogues or websites (anything online?) where I can find standard pipe shaft sizes?
Standard pipe shaft sizes refer to the standardized measurements of pipes used in various industries, including plumbing, construction, and manufacturing. These sizes typically range from 1/8 inch to 24 inches in diameter and are measured based on the inside diameter (ID) or outside diameter (OD) of the pipe.
You can determine the standard pipe shaft size for your project by consulting catalogs or websites that provide detailed information on pipe sizes and dimensions. These resources often include charts and tables that list the different standard sizes and their corresponding measurements, making it easy to find the right size for your specific needs.
Yes, there are different standard pipe shaft sizes for different types of pipes. For instance, PVC pipes have their own set of standard sizes, while steel pipes have a different set of standard sizes. It is important to consult the appropriate catalog or website for the type of pipe you are using to ensure you are using the correct standard size.
Yes, standard pipe shaft sizes can also be used for non-industrial purposes such as DIY projects or home renovations. Many hardware stores and home improvement retailers carry pipes in standard sizes that can be used for various projects. However, it is important to keep in mind that these standard sizes may not be suitable for industrial or heavy-duty use.
Yes, there can be variations in standard pipe shaft sizes across different countries. While many countries follow similar standards, there can be slight differences in measurements or terminology. It is important to consult catalogs or websites specific to your country or region to ensure you are using the correct standard size for your project.
