Line Integral: Applying Standard Test to Find Dependency
In summary: Of you have used it to determine "if it is a perfect differential" (I would say exact differential) but don't know how that would help you whether the integral depends only on the endpoints, then yes, you need to read up on what perfect differentials mean!It doesn't help to determine whether a differential is "perfect" (exact) if you don't know what it means!Yup, my notes say both exact and perfect, I don't know how it helps either, I have 2 equations, F (small x) = 2x-y and F(small y) 1-x, denoting the 2 separate components, I have the line integral, by going along x, then y, I'm
Davio
65
Hiya, I've just done a line integral question, and the final part of the question is, "by applying a standard test, determine whether the value of the line integral depends on the path followed between the given initial and final points." The only standard test, I know, is dq/dx, and dp/dy to find if its a perfect differential. I somehow doubt that's the correct standard test :-p. Does it mean, to try calculating it again, but with different forumla?
… contour integral …
Hi Davio! :smile:
Join two different paths together, in opposite directions, to make a circuit (a contour). Then the value of the line integral is independent of the path iff the contour integral is always zero.
Do you know a test for the contour integral being zero? :smile:
Why do you doubt that is the correct test? It sounds perfectly reasonable to me.
I doubt its the correct test, because, well it doesn't mean anything to me, I've only ever used it to determine if its a perfect differential, and then solved it! Surely it means you can just express it in a certain form?
@Tiny tim, nope I don't know it? Unless its the perfect differential thing I mentioned ... in which case I'm being silly and need to read up on what perfect differentials mean!
Hi Davio! :smile:
If you haven't done it yet in class, then just follow HallsofIvy's good advice! :smile:
:-D ok will do! Like I said, guess i need to read up on perfect differential's!
Yup, my notes say both exact and perfect, I don't know how it helps either, I have 2 equations, F (small x) = 2x-y and F(small y) 1-x, denoting the 2 separate components, I have the line integral, by going along x, then y, I'm guessing its asking if it makes a different if I just go from (-1,-1) to (1,1)? If I differentiate, Fx and Fy to y and x respectively, I get -1 in both cases, does this help me?
Then learn what a "perfect" differential is!
If F(x,y) is a function of the two variables, x and y, and we evaluate F along a path in the plane with parametric equation x(t), y(t), by the chain rule,
[tex]\frac{dF}{dt}= \frac{\partial F}{\partial x} \frac{dx}{dt} + \frac{\partial F}{\partial y}\frac{dy}{dt}[/tex]
or, in "differential notation"
[tex]\dF= \frac{\partial F}{\partial x}dx+ \frac{\partial F}{\partial y}dy[/tex]
which does NOT depend on the particular parameter t!
In other words, f(x,y)dx+ g(x,y)dy is a "perfect" differential if there really does exist a function F(x,y) such that dF= f(x,y)dx+ g(x,y)dy. That is the same as saying that
[tex]f(x,y)= \frac{\partial F}{\partial x}[/tex]
and
[tex]g(x,y)= \frac{\partial F}{\partial y}[/itex]
If that is true, then for any curve, C, between point P and Q
[tex]\int_C f(x,y)dx+ g(x,y)dy= F(x,y)\right|^Q_P[/tex]
which depends only on the endpoints P and Q, not on the curve itself.
I can think of no reason for learning how to test whether or not a differential is a "perfect" differential without knowing what a "perfect" differential is!
1. What is a line integral?
A line integral is a type of integral in multivariable calculus that is used to calculate the total value of a function along a specific path or curve.
2. How is a line integral applied?
A line integral is applied by breaking a curve or path into small segments and finding the sum of the values of the function at each point. This sum is then integrated to find the total value.
3. What is the standard test for finding dependency in a line integral?
The standard test for finding dependency in a line integral is the Fundamental Theorem of Line Integrals, which states that the value of a line integral can be calculated by evaluating the function at the endpoints of the curve and subtracting the values.
4. Why is it important to find dependency in a line integral?
Finding dependency in a line integral is important because it allows us to determine if the value of the integral is influenced by the path taken or if it is solely dependent on the endpoints of the curve. This can help us simplify calculations and make predictions about the behavior of the function.
5. What are some real-world applications of line integrals?
Line integrals have many real-world applications, such as calculating the work done by a force on an object, finding the center of mass of a 3D object, and determining the flux of a vector field through a surface. They are also used in physics, engineering, and other fields to solve various problems involving curves and paths.
