Standing Waves in Strings: Examining Amplitude, Node Number, and Wave Speed
In summary: Since the windows are different lengths, the frequencies cannot be the same.In summary, the figures show systems of standing waves set up in strings under the same tension, but with different lengths and amplitudes. The wave speed does not depend on the amplitude of the wave, and Figure E has a wavelength of 20 cm. Figure B has the most nodes, and all of the standing wave patterns have the same wave speed. However, Figures C and F have different frequencies due to their different window lengths.
BMWPower06
92
The figures below show systems of standing waves set up in strings, fixed at both ends, under tension. All of the strings are under the SAME tension and are otherwise identical, EXCEPT for their lengths. The variables in these situations, in addition to the lengths (L) of the strings, are the amplitudes (A) at the antinodes and the number of nodes in the standing wave.
http://aycu10.webshots.com/image/21209/2002759293776541254_rs.jpg
Which of the following statements are true about the situations depicted in the figures above?
True False The wave speed does not depend on the amplitude of the wave
True False Figure E has a wavelength of 20 cm
True False Figure B has the most nodes
True False All of the standing wave patterns have the same wave speed
True False Figures C and F have the same frequency
I looked through my book, and i know that I am close, I am just not sure which ones are wrong. My answers are in bold, and the computer says its wrong, but not which ones are wrong. Any help?
Thanks
Which ones are you unsure of? What is your reasoning behind your answers?
Well:
1) V= Sqrt T/U so i think that's right
2) Wavelength is from one antinode to another, so i think that is right
3) Figure B has the most frequency so it has the most nodes
4) Not too sure about this one
5) They both have 3 occurences in the same period so they must be the same
I don't know which is wrong, i tried changing number 4 but that was still wrong.
BMWPower06 said:
Well:
OK
From one antinode to the next is a half wavelength, but OK.
You can just count the nodes.
What does wave speed depend on?
Why do you think the period is the same?
Doc Al said:
OK
4. length and tension/force
5. because they are all in the same window, but I am not too sure
Wave speed does not depend on length. Review the formula that you quoted regarding question 1.
The windows are not all the same size. Check the length of each window, which is labeled on the diagram.
1. What are standing wave figures?
Standing wave figures, also known as stationary wave figures, are patterns of vibration formed when two waves with the same amplitude and frequency travel in opposite directions and interfere with each other.
2. How are standing wave figures created?
Standing wave figures are created by the interference of two waves with the same amplitude and frequency traveling in opposite directions. This causes the waves to cancel out and form stationary points, known as nodes, and regions of maximum amplitude, known as antinodes.
3. What is the relationship between standing wave figures and resonance?
Standing wave figures are a result of resonance, which occurs when an object is forced to vibrate at its natural frequency by an external force. In the case of standing wave figures, the natural frequency is the same as the frequency of the two interfering waves.
4. How can standing wave figures be used in practical applications?
Standing wave figures have various practical applications, such as in musical instruments, where they help produce specific notes and harmonics. They are also used in non-destructive testing to detect flaws in materials by analyzing changes in standing wave patterns.
5. What factors affect the formation of standing wave figures?
The formation of standing wave figures is affected by various factors, including the amplitude, frequency, and wavelength of the interfering waves, as well as the medium through which the waves are traveling. Additionally, the boundary conditions of the medium can also impact the shape and position of the nodes and antinodes.
