Standing waves problem
  1. Oct 17, 2013 #1
    A string of length 1.5m with its two ends clamped is vibrating in fundamental mode. Amplitude at the center of the string is 4mm. Find the distance between the points who have amplitude 2mm.
    2. Relevant equations
    y=Asinkxcoswt
    λ=2*L
    3. The attempt at a solution
    First of all i was trying to get the distances of the points from one of the nodes.
    so putting t=0 i get y=Asinkx
    k=2π/λ
    λ=2*L = 2*1.5 = 3
    so y= Asin[itex]\frac{2π}{λ}[/itex]x
    i know the amplitude is 2mm which is half the max amplitude.
    [itex]\frac{A}{2}[/itex]=Asin[itex]\frac{2π}{λ}[/itex]x
    So that gives
    0.5=sin[itex]\frac{2π}{λ}[/itex]x
    [itex]\frac{π}{6}[/itex]=[itex]\frac{2πx}{λ}[/itex]
    0.25=x
    Now the other partical will be 1.25m from the node.
    so the difference is 1m
    but the answer given is 50cm
    Where i have gone wrong??
  3. Oct 17, 2013 #2
    I believe your solution is correct, the answer given is wrong. for a normal traveling wave the answer would be would be 50cm but this is a standing wave (n=1) with nodes at its two ends so I believe your answer is correct!!!
Have something to add?
Draft saved Draft deleted
Similar Discussions: Standing waves problem
  1. Standing Wave Problem (Replies: 0)
Loading...
