Standing Waves
  • Thread starter bodensee9
An aluminum wire of length .6 m, cross sectional area of .01 cm^2, density 2.60 g/cm^3, is tied to a steel wire of density 7.8 g/cm^3 and the same cross sectional area. The compound wire is joined to a pulley and then a block of mass 10 kg is tied at the end of the steel wire. Thisi is arranged so that the distance from the joint (where the 2 wires meet) to the pulley is .866m. Transverse waves are set up at a variable frequency with the pulley as a node. Find the frequency that generates a standing wave having the joint as one of the nodes.
---aluminum---x---steel-----------pulley
10kg mass
So the length of the aluminum part is .6m and the steel part is .866m.
So do I find the total mass of the wire, then divide that by the length (1.466m) to find the density. And then I use v = sqrt(tension/density) and then f = n*v/2*L to find the frequency, where L is the length of the wire?
I don't see how both the .6m and the pulley can be a node? They aren't really multiples of one another, and so I'm wondering how I am to find n?
Thanks much!
Answers and Replies
The picture doesn't appear right; the mass is hanging on the pulley side. Thanks.
alphysicist
2,238
Hi bodensee9,
10kg mass
I don't believe that is right; here you need to treat the aluminum wire and the steel wire separately. But think about what quantities will be the same for the two wires.
Thanks much!
The two wires will have different linear mass densities; do you see how that will help?
Hello:
I think the tension is the same in both parts of the wire because they are connected? If I treat the two wires separately, wouldn't they have a different v? I am wondering though how the cross section area is relevant in that case ...
Thanks!
alphysicist
2,238
Hello:
Thanks!
That's right: the tension is the same in both wires. You are also right that the velocity of the wave in the different wires will also be different; but what is the same for the wave in the steel and the wave in the aluminum?
I think once you start calculating, you'll probably see where the cross-sectional area becomes important.
Hello:
Do the wavelengths have to be the same for both waves? Thanks.
alphysicist
2,238
Hello:
No, I don't think so. And there's no problem with the wavelength being different in each wire; since each wire has a node on each end (counting the pulley as one of the ends), it's almost like each wire is a separate problem. But what has to be the same, and why?
Related Threads on Standing Waves
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
