1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Standing Waves
  1. Sep 21, 2008 #1
    Two speakers are driven in phase by a common oscillator at 800 Hz and face each other at a distance of 1.25 m. Locate the points along a line joining the two speakers where relative minima of sound pressure amplitude would be expected (Use v = 343 m/s).
    This problem ended up screwing my mind until I found out that the waves are supposed to be, as the problem said, in phase. I was able to get the answer, which are .518 m, .303 m, .0891 m, .732 m, .947 m, and 1.16 m from either speaker. However, in the solutions book, the way they did it was by stating that the point halfway between the speakers (.625 m) is an antinode of pressure, and since the distance between adjacent nodes is .214 m and adjacent node-antinodes is .214/2 m, they used .625 - .214/2 = .518 m to find a pressure node. Then they added/subtracted .214 m to get the other values. The statement about the midpoint being a pressure antinode began to screw my mind. They didn't prove anything for it, they stated it as seemingly a postulation out of nowhere...how do they know the midpoint is an antinode?
  3. Sep 21, 2008 #2
    d-_-b
  4. Sep 21, 2008 #3
    LowlyPion
    The point that is equidistant means that the sound arrives from each speaker at the same time, if they are in phase. Shouldn't you expect a maximum at that point of twice the amplitude? The sound from one speaker 1/4 shy of the mid point added to the one from the other side that has been traveling 1/4 longer then is 1/2 out of phase isn't it?
  5. Sep 21, 2008 #4
    But how do we know it is not a node?
  6. Sep 21, 2008 #5
    LowlyPion
    It can't be a node. At the mid point there is by definition constructive interference because the sound is in phase and equidistant from the 2 sources. Destructive interference must be 180 degrees out of phase.
  7. Sep 21, 2008 #6
    O_O!!! Good point you make...but to make sure of things...this requires that if a wave immediate to one speaker is, say, compressional, then the wave immediate to the other speaker is also compressional, right?
  8. Sep 21, 2008 #7
    LowlyPion
    How would they be in phase otherwise?
  9. Sep 21, 2008 #8
    I see...Thanks for the clarification
Similar Discussions: Standing Waves
  1. Standing waves (Replies: 2)
Loading...
