Homework Help: State Vector and Probability
  1. Nov 2, 2015 #1
    RJLiberator
    Find a state vector |v> ∈ ℂ^2 such that if a measurement of δx is made on a qubit in this state, then the prob. of obtaining the value of +1 in the measurement is 9/10. What is <δx> in this case?
    2. Relevant equations
    State Vectors: https://en.wikipedia.org/wiki/Quantum_state
    3. The attempt at a solution
    This problem seems somewhat simple to me, but I want to make sure I have the simple case down before moving forward.
    We seek to find a state vector that when taking a x-hat measurement results in a prob(+1) = 9/10 and thus a prob(-1) = 1/10.
    Therefore, if we let |v> = ( λ, μ ) then we know that prob(+1) = |λ+μ|^2/2 and prob(-1) = |λ-μ|^2/2
    Since we know what these need to equal, it's clear to see that λ = 2/sqrt(5) and μ=1/sqrt(5) is a solution.
    Thus, <δx> is calculated as |α|^2-|β|^2 where α = (λ+μ)/sqrt(2) and β = (λ-μ)/sqrt(2). So, <δx> = 8/10=4/5.
    So, the state vector is thus 1/sqrt(5) (2,1).
    My concern is that I am not understanding the correct definition of state vector? Does a state vector 'have' any requirements that I am missing?
    Are my calculations correct?
  3. Nov 3, 2015 #2
    RJLiberator
    A friendly bump for this question.
    My main concern is the <δx>.
    I did this same experiment for δy and got the same exact average of 4/5.
  4. Nov 4, 2015 #3
    RJLiberator
    Okay, let me simplify what I am asking then:
    Is this a capable result? Does 2/sqrt(5) + 1/sqrt(5) need to equal 1? Or does it matter?
    We see that if we square it, it does indeed equal 1, 4/5+1/5 = 1.
  5. Nov 5, 2015 #4
    DrClaude
    Staff: Mentor
    Is that correct: measurement of δx, not x?
    Most often, you want states to be normalized.
  6. Nov 5, 2015 #5
    RJLiberator
    Hm...
    First, my state vector is not normalized, correct?
    Second, since you said 'most often' does that mean I should go find a normalized state vector or is my answer fine?
    With my notation of <δx> I am looking to find the average value. It should be defined as |α|^2-|β|^2
  7. Nov 5, 2015 #6
    DrClaude
    Staff: Mentor
    Yes, your state vector is normalized, which is what you most probably want. My comment was only to clarify that state vectors don't have to be normalized, but most of the time people will expect them to be.
    Then I don't understand the original problem:
    This means that δx must be an observable. I don't see which operator it corresponds to.
  8. Nov 5, 2015 #7
    RJLiberator
    |v>|v> = 1 is the definition of normalized and so my vector is normalized? I understand! Thank you kindly.
    I wasn't sure of my calculation, it seems a bit too obvious. |α|^2 = prob(+1) and |β|^2 = prob(-1). If this is so, then it is obvious in the first 2 seconds of this problem that it is 9/10-1/10 = 4/5 since the probabilities must add up to 1.
    The next question on my assignment asks me to repeat this process only with the y version instead of the x. The same situation occurs, 9/10-1/10-4/5 for the average value.
    It 'feels' like I am misinterpreting something for it to be this simple.
    Once again, thank you kindly for your time, this is important for me to clarify and understand and its a difficult topic to discuss over a message board with such notation!
  9. Nov 5, 2015 #8
    DrClaude
    Staff: Mentor
    Not exactly: the norm of a state is ##\langle v | v \rangle##.
    As for the rest, I just figured out what you mean: my problem is that you used the wrong symbol, and that confused me. When you write δx, you mean σx, one of the Pauli spin matrices, right?
    In that case, lets see. If the state is
    | \psi \rangle = \frac{2}{\sqrt{5}} | \alpha \rangle + \frac{1}{\sqrt{5}} | \beta \rangle
    what is the probability of measuring the system in state ##| \alpha \rangle##?
  10. Nov 5, 2015 #9
    RJLiberator
    The probability of |α> is (2/sqrt(5)) ^2 so it would be 4/5.
    The probability of |β> is thus 1/5
    4/5+1/5 = 1 so that checks out.
    Now using the average, we see that 4/5-1/5=3/5 as the average which is different compared to my value.
    Your way seems to be more correct (via intuition), but when I look at my paper, I'm not sure how I messed up.
    prob(+1) = |α|^2 = |λ+μ|^2/2 = 9/10. If we choose λ = 2/sqrt(5) and μ=1/sqrt(5) as the state vector this works out.
    So, I guess, why are you using |α> to equal = 2/sqrt(5) instead of α = (λ+μ)/sqrt(2)?
    This question should solve any errors.
  11. Nov 5, 2015 #10
    DrClaude
    Staff: Mentor
    Please accept my apologies. I was confused at the beginning by δx, and that lead me in the wrong direction.
    You calculations in the OP are correct.
  12. Nov 5, 2015 #11
    RJLiberator
    Thank you for taking the time to look through this. I greatly appreciate it.
    Kind regards!
Have something to add?
Draft saved Draft deleted
Loading...
