Homework Help: Static equilibrium problems
  1. Oct 19, 2006 #1
    hey every1... i'm stuck on this problem and unless i get it and a few others right im gonna fail my engineering statics course :( im desperate! I study aerospace engineering but because i've been ill i missed a few classes and i really dont have time to learn the theory to answer these... thank you for your time.
    Here's the diagram for the 1st Q:
    http://img383.imageshack.us/my.php?image=q1cm6.jpg
    The Q that goes with it is:
    Determine the bending moment at a distance x from the roller support on the left hand side, using the principles of virtual work.
    The values are: F = 2kn, d=2.200m and x=0.600m
  3. Oct 19, 2006 #2
    2nd Question:
    http://img407.imageshack.us/my.php?image=q2un0.jpg
    Each of the two uniform hinged bars have a mass m and length L. Both bars are connected by hinge S and supported as shown. The structure is loaded by a mass of 4m, applied at the hinge S. Gravitational acceleration is g = 9.81m/s2.
    m= 15kg
    L=5.500m
    angle theta= 130 degrees
    Calculate the torque Ma (in Nm) required for equilibrium
  4. Oct 19, 2006 #3
    radou
    Working on it. :rolleyes:
  5. Oct 19, 2006 #4
    your saving my academic life! thankyou!
  6. Oct 19, 2006 #5
    radou
    http://usera.imagecave.com/polkijuhzu322/system1.bmp.jpg"
    Ok, as said, the system is replaced with a mechanism, where a hinge is put in the place where you have to find the moment, and there is a couple of moments M added to that same place. Now, you have to construct an initial relative rotation between the two diskd connected by the hinge, so do it as is done in the displacement sketch. Now all you have to do is apply the principle of virtual work to get the moment M: [tex]F\cdot d_{F}+M(A_{1}+A_{2}) = 0[/tex], where A1 and A2 are the angles of rotation of the two disks.
  7. Oct 19, 2006 #6
    radou
    Regarding the second assignment, replace the system with a system where the force G = mg acts in the center of each bar, and where G' = 4mg acts on the hinge. Try this: [tex]\sum M_{(A)}=0 \Rightarrow R_{B} = \cdots ; \sum F_{yi}=0 \Rightarrow R_{A} = \cdots ; \sum M_{(B)}=0 \Rightarrow M_{A} = \cdots[/tex] I hope this works.
  8. Oct 19, 2006 #7
    thanks for the effort, but i dont fully 'get it' :(
    so what i have so far is:
    F . df + M(A1 + A2)=0 which i think is
    2 X df + M(40.36 + 8.53) = 0
    ok and using trigonometry i got that df is 0.606711 m, so
    i get that M = 0.024819 kNm... is that right?
  9. Oct 19, 2006 #8
    radou
    M should equal -0.54 kNm, I checked on it. You obviously didn't do the trigonometry right. [tex]\frac{0.6}{4}=\frac{d_{F}}{4-2.2}[/tex], [tex]A_{1} = \tan A_{1} = \frac{3.4}{4}[/tex], and [tex]A_{2} = \tan A_{2} = \frac{0.6}{4}[/tex]. I forgot to point this out - A1 and A2 are differential rotations, so in the theory of small displacements you can use the identity [tex]\alpha \approx \tan(\alpha)[/tex].
  10. Oct 19, 2006 #9
    double post
  11. Oct 19, 2006 #10
    yea i made a mistake with the trigonometry, am gonna try the 2nd Q now but i dont have much confidence that i'll get the right answer. pleaseee stick around to correct me im certain i'll make a mistake, thx again.
    ok so i drew a free body diagram of the system, with mg acting downwards on the centre of each member, and 4mg acting downwards on hinge A. Then i calculated the vertical reaction force at B from moment equilibrium about point A, and got that Bv = 73.582kN
    then summing forces in the y direction gives that Av = 809.318kN and summing forces in the x direction gives that Ax = 0. But now im not sure what to do! lol.... i know all the forces but am not sure how to calculate the torque at Ma... i mean, i think i can do it without using virtual work... by summing all the moments about point A, and then the reaction moment would be negative of that right.... but have no idea how to do it with virtual work, the idea of displacements confuses me.
    do u have maybe msn or yahoo radou?
  12. Oct 19, 2006 #11
    radou
    P.S. If you're certain you'll make a mistake, then you will make a mistake. Conslusion: don't be certain you'll make a mistake. :wink:
  13. Oct 19, 2006 #12
    is there anybody, out there? (pink floyd)
  14. Oct 19, 2006 #13
    radou
    Unfortunately, no msn neither yahoo. :biggrin:
    Btw, it doesn't say anywhere that you have to use virtual work in assignment 2. Your way of thinking about 2 seems correct.
  15. Oct 19, 2006 #14
    hey are u still out there radou? could u possibily help me on another couple questions? :!!)
  16. Oct 19, 2006 #15
    radou
    As long as I'm online, I'll help. :smile:
  17. Oct 19, 2006 #16
    thankyou! btw, i know this will sound rude as some1 can sound... but i have 8 more Q's and if i dont get them all right i really am gonna fail this course :( could i maybe just have the answers? believe me when i say that, i will learn the theory behind all of this stuff but i reallly am in need of nothing less than a miracle just now...
  18. Oct 19, 2006 #17
    radou
    Depends on how big the questions are. Btw, answers won't help you if you don't understand anything. But nevermind, let's give it a try. :rolleyes:
  19. Oct 19, 2006 #18
    ok this is actually Q11
    http://img120.imageshack.us/my.php?image=qmc9.jpg
    a= 0.200m
    b=2m
    theta= 35 degrees
    Determind the torque M (in kNm) on the activating lever of the dump truck necessary to balance the load at the given dump angle theta, g = 9.81m/s2.
  20. Oct 19, 2006 #19
  21. Oct 19, 2006 #20
    radou
    These are all very similar (and typical) statics assignments, so, if you solved the one at the beginning of the thread (the one without virtual work), then you should know how to solve these one. As said before, use the fact that a system is in equilibrium if the sum of all moments of the forces acting on it (including couples, as in Q3) with respect to any point must vanish, as must the sum of all horizontal and vertical forces (i.e. compoments of forces). Pick the 'moment equation point' wisely - it's a way to elliminate unknowns.
