Static friction and work
arildno
Dearly Missed
9,948
130
Caveat:
Pixel is defining his system in such a manner so that it is not apparent to him that static friction is doing work on the lower box.
That, however, doesn't make his system "wrong", merely unsuitable for analyzing the particular situation at hand.
688
OK, I have another scenario. A spring is connected to a mass at one end and fixed at the other. Now, you make the system oscillate by one force. The system can oscillate for very long time. If we consider the connection can do work (it's similar to a string etc..), that means there's time the work is negative and sometimes the work is positive.
I am not sure if the work done can be a negative value?
In thermaldynamics, the work done is always positive.
arildno
Dearly Missed
9,948
130
Why move to another scenario?
It is not at all obvious you have understood the previous one.
This new example is clearer to explain the work done I think. If the connection can do some work, we have to accept some negative work and that is impossible.
russ_watters
Mentor
18,640
4,874
Caveat:
Yes, you are correct. In *his* box scenario, there is no motion between the boxes, therefore no work being done between the boxes. He's correct about that. But in *our* box scenario, there is motion between the box and the ground and therefore work being done on the lower box by the upper box with respect to the ground.
He's basically using a scenario where no work is being done to say that no work can be done, while we are showing a scenario where work is being done.
Doc Al
Mentor
44,765
1,044
Of course work can be negative and that's true in thermo as well!
russ_watters
Mentor
18,640
4,874
No, it isn't. It isn't even remotely similar to the other scenarios and does not discuss the same concept. You are now asking if work can be negative, which has nothing to do with whether static friction can cause work to be done.
In any case, the answer to the new question is yes, work can be negative. Work (energy) can either go into or out of a system. Work in is positive, work out is negative. Looking at the net work equation , if the work out is greater than the work in, the net work is negative. http://en.wikipedia.org/wiki/Work_(thermodynamics)#Mathematical_definition
In the spring example, at one time, the spring pulls the mass, and the connection does a work. at other time, the mass pulls the spring, the connection should then consume work or does negative work? If we accept that the knot can create work?
russ_watters
Mentor
18,640
4,874
You mean the connection between the mass and the spring? Yes, if you didn't know the spring was there, you could say that the knot did work on the mass (+), then the mass did work on the knot (-). [incidentally, if you ignore the spring, now the scenario is pretty much identical to the previous scenario of a string pulling a mass]
russ_watters
Mentor
18,640
4,874
Try this, pixel01 - draw a picture of the system, then draw a circle around the part you want to analyze. For any of these scenarios, knowing how to properly define the system is the key. For the stacked-boxes example, you would draw your circle around the ground, the entire lower box, and part of the upper box - but not the person's finger. That way the only force you are looking at is the force between the boxes and the only motion is between the lower box and the ground.
688
Right, the work can be negative and the spring example is meaningless.
Anyway, I am not convinced at the statement: static friction (or string, bolts or nuts...) can do work.
i think we can say that static friction is capable of doing work in certain frames of reference.
russ_watters
Mentor
18,640
4,874
Not sure how to help you - have you tried drawing a picture?
arildno
Dearly Missed
9,948
130
Why not?
You have some type of misconception here.
Related Threads for: Static friction and work
  • Posted
  • Posted
9K
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
