Static load of linear actuator
In summary, the conversation is about measuring an object using an electric scale and selecting a linear actuator to hold the object at a fixed height. The confusion lies in the different units used by manufacturers and whether gravity is taken into consideration when measuring weight in kilograms. The electric scale measures weight in grams of force due to gravity, while mass is measured by the force required to accelerate an object to 1m/s2. Lbs and pounds are the same unit, but the term "lbs" may be from the ancient Roman libra.
bbq_build
62
Hello, I measured an object using an electric scale. It is 5kg. I want to select a linear actuator such that when placed vertically, it can keep the object on hold at a fixed height. In this case, what static load (in lbs and Netwon) should the actuator be capable of handling? I am confused by different units listed by different manufacturers. Thanks.
Use Google. If you enter: convert 5kg it will show hints for what to convert it to (pounds, grams, Newtons, stones)
I know how to do conversion using google. The confusion I have is whether the manufacturers and the electric scale take gravity into consideration when showing the numbers. For example:
When I measured the weight of the object using a scale, it reads 5kg. So, in Newton, it is 5kg*9.81m/s2 ~= 50N. However, objects are under gravity. So, the electric scale measured the object under gravity. Shouldn't that 5kg has already included an increased scale factor of 9.81? Does the electric scale takes gravity into consideration when showing weight in kg?
When manufacturers state the static load, I am not sure if they have taken gravity into consideration. For example, if the stated static load of a motor is 100N, does that mean it can hold an object of about 10kg? Similarly, if a company states that their motor has a static load of 500 lbs, does that mean it can hold an object of about 227kg. (If the object is put on an electric scale, it gives 227kg?) 227kg is the value given by a calculator I found using google. Seem to be too large.
Yes. Electric (or electronic) scales are glorified spring scales, you are measuring Grams of Force (due to gravity). If you take that scale and 5kg weight to the Moon, the scale will read about 0.83kg. That's because gravity on the Moon is about 1/6 of Earths gravity. If you want to measure Mass, you use a Balance and put the unknown mass in one pan and put various known masses in the other until the scale "balances." Then you will get the same readings whether you are on Earth, the Moon or Jupiter.
Addendum: The classical way of measuring mass is to find the force required (in Newtons) to accelerate the mass at 1 meter per second, per second. The answer is the mass in kilograms. That works anywhere, on any planet or even in space. (because that is the definition of a Newton)
So just keep things sorted out in your mind: Weight is grams, pounds, stones, etc, of force on an object due to gravity; Mass is measured by how much force it takes to accelerate that object to 1m/S2.
Enjoy!
Tom
Likes bbq_build
Thanks Tom. Sometimes manufactures use lbs as the unit of the static load. For most google unit conversions , they use pounds. Are they the same thing? In other words, is 1 lbs = 1 pound? lbs does not sound like an abbreviation of pound.
Yes, the same, isn't English weird?
According to wikipedia, lb is from the ancient Roman libra, from the Hellenic system, which was built on the Egyptians, who were influenced by the Mesopotamians!
Here is the link to wikipedia:
https://en.wikipedia.org/wiki/Pound_(mass)
1. What is the definition of "static load" for a linear actuator?
Static load refers to the maximum weight or force that can be applied to a linear actuator while it is not in motion. This is important to consider when selecting a linear actuator for a specific application, as exceeding the static load limit can cause damage or failure.
2. How is the static load capacity of a linear actuator determined?
The static load capacity of a linear actuator is determined by its structural design and the materials used to construct it. The manufacturer will typically test the actuator under various load conditions to determine its maximum capacity.
3. What factors can affect the static load capacity of a linear actuator?
The static load capacity of a linear actuator can be affected by factors such as the type of load (compression or tension), the angle at which the load is applied, and the speed of the actuator. Additionally, environmental factors such as temperature and humidity can also impact the static load capacity.
4. Is the static load capacity the same as the dynamic load capacity for a linear actuator?
No, the static load capacity and dynamic load capacity are not the same for a linear actuator. The dynamic load refers to the maximum weight or force that the actuator can handle while in motion, and it is typically lower than the static load capacity. This is because the actuator experiences more stress and strain when in motion compared to when it is stationary.
5. How can I ensure that I am not exceeding the static load capacity of a linear actuator?
The best way to ensure that you are not exceeding the static load capacity of a linear actuator is to carefully read the manufacturer's specifications and guidelines. This will provide you with the maximum weight or force that the actuator can handle, as well as any other important information for its safe operation. Additionally, it is important to properly install and maintain the actuator to prevent any potential damage or failure due to overload.
  • Other Physics Topics
  • Mechanical Engineering
15K
15K
  • DIY Projects
  • STEM Academic Advising
