How Much Torque Does a Person Exert on a Ladder?
  • Thread starter courtney1121
  • Tags
    Static
In summary, a person with a weight of 650 N stands on a ladder at a point 1.0 m from its bottom and exerts a torque of 222.3 J around the point where the ladder touches the ground. The magnitude is correct, but the direction is incorrect.
courtney1121
68
Imagine that a ladder leans against the house at an angle of 20o with respect to the vertical. A person with a weight of 650 N stands on the ladder at a point 1.0 m from its bottom. What are the magnitude and direction of the torque that this person exerts on the ladder around the point where the ladder touches the ground?
Where do I start?
Where do I start?
Start by drawing a sketch, showing the angle the ladder makes with the wall, then look up the definition of torque. What do you get?
Well torque will be T=rFsinx
x = 20 degrees
r = 1m
F=650
so T=1(650)sin(20) = 222.3?
Is the direction towards me then? If I am looking at the house, the ladder is on the right of the house.
From using the right-hand rule, I determined that the torque will be counter-clockwise towards me...but I usually mess up the right hand rule somehow...
Magnitude is correct, don't forget units!(joules).
Direction is also correct, using right hand rule, curl your fingers of your right hand in the direction of the force, with your thumb in the direction of the axis about which the torque is taken. Your thumb will point in the direction of the torque, which in this case is out of the plane towrd you along the z axis. The torque is counterclockwise. For practice, try the same problem, but with the ladder on the left side of the house. What do you get for a magnitude and direction of the torque in this case?
well, the torque will be the same but shouldn't it be negative so -222.3J and the direction would be towards me again but clockwise?
What are you afraid of straining your wrist? The direction is clockwise, but AWAY from you this time. You must get that thumb passing through the point about which the torque is taken. That negative sign indicates that the direction is opposite the direction in the first case when the ladder was on the other side. Usually clockwise moments are considered positive, and counter clockwise moments are negative, but it doesn't generally matter too much as long as you are consistent. Try it again, and strain your wrist and you'll get it!
haha people are looking at me like I'm trying to hitch hike in my room...but i see now why it is pointing away from me.
Ya, thanks a lot, now i need an Ace bandage.
im sorrrry! :(
1. What is the "static ladder lean problem"?
The static ladder lean problem is a phenomenon where a ladder placed on a flat surface appears to lean to one side, even though it is balanced and not being affected by external forces. This can be observed when the ladder is viewed from a distance or from a certain angle.
2. Why does a ladder lean when it is not being touched?
This is due to an optical illusion called the "lean effect". Our brain interprets the visual cues of the ladder's surroundings and creates the illusion that the ladder is leaning, when in fact it is standing straight.
3. Can this problem affect the stability of the ladder?
No, the static ladder lean problem is purely a visual illusion and has no impact on the stability of the ladder. As long as the ladder is placed on a flat and level surface, it will remain stable and safe to use.
4. Does the type of surface the ladder is placed on affect the static ladder lean problem?
Yes, the type of surface can play a role in the appearance of the ladder lean. For example, a checkerboard patterned surface can enhance the lean effect, while a solid colored surface may minimize it.
5. How can I prevent the static ladder lean problem?
Since the static ladder lean problem is an optical illusion, there is no way to completely prevent it. However, you can minimize the effect by adjusting the position and angle of the ladder, or by using a level to ensure it is placed on a completely flat surface.
