Homework Help: Statically Indeterminate Shaft
  1. Apr 16, 2013 #1
    Determine the load (vertical only) on the three bearings at A, B and C. The shaft is loaded at one end with force F (see attached diagram).
    2. Relevant equations
    Cantilever Beam Deflection
    Deflection at End = PL^3/(3EI)
    Deflection at Point X = Px^2/(6EI)*(3l-x)
    3. The attempt at a solution
    I'm having a few difficulties remembering the details of solving statically indeterminate problems. My attempt is as follows:
    1. Remove reaction forces B and C. Applying beam deflection formulas I can find the displacement of points B and C due to force F. I called these δB1 and δC1.
    2. Replace the reaction forces at B and C, but remove the force F. I can now find the displacement of points B and C due to the reaction forces, respectively. I called these δB2 and δC2.
    3. Since the actual deflection at the fixed points B and C is zero, I can set:
    δB1 + δB2 = 0
    and similarly
    δC1 = δC2
    This leaves 2 equations and 2 unknowns which may be solved.
    Any hints, comments or corrections would be a world of help :smile:
  3. Apr 16, 2013 #2
    PhanthomJay
    All supports take vertical load only (simple supports) and cannot carry moment, so the support at A is not fixed and cannot act that way when supports B and C are removed. The beam is statically indeterminate to the first degree, so you need to initially remove just one support.... like perhaps B.
Have something to add?
Draft saved Draft deleted
