jcsolis
- 38
- 1
Show that AXB is not equal to BXA
No variables given..just this equation
I don´t know how to start...the only thing I know so far is that AXB is equal to -BXA
The cross product, also known as the vector product, is an operation that takes two vectors and produces a third vector that is perpendicular to both of the original vectors. In statics, the cross product is used to find the moment of a force about a point, which is important in analyzing the equilibrium of a rigid body.
The cross product of two vectors, A and B, is calculated by taking the magnitude of A, the magnitude of B, and the sine of the angle between them, and then multiplying them together. The result is a vector that is perpendicular to both A and B, and its direction is determined by the right-hand rule.
The cross product and the dot product are both mathematical operations involving vectors, but they have different results. The dot product produces a scalar (a number), while the cross product produces a vector. In statics, the dot product is used to calculate the work done by a force, while the cross product is used to calculate the moment of a force.
In statics, the cross product is used to calculate the moment of a force about a point. This is important in determining the equilibrium of a rigid body, as the sum of all moments must be equal to zero for the body to be in static equilibrium. The cross product is also used in calculating the torque exerted by a force on a rigid body.
Yes, the cross product can be used in 2D statics problems, but it is typically only necessary in cases where the forces are not coplanar (lying in the same plane). If all of the forces in a 2D problem are coplanar, the cross product will result in a vector pointing directly out of the plane, which can be ignored in 2D calculations. However, in 3D statics problems, the cross product is essential for finding the moment of a force about a point.
