• Support PF! Buy your school textbooks, materials and every day products Here!
Statics Problem Help
Assume that each member of the truss is made of steel
having a mass per length of 4 kg/m. Set p=0 , determine the
force in each member, and indicate if the members are in
tension or compression. Neglect the weight of the gusset plates
and assume each joint is a pin. Solve the problem by assuming
the weight of each member can be represented as a vertical
force, half of which is applied at the end of each member.
[Broken]
Ʃm=0
Ʃfx=0
Ʃfy=0
I don't really know how to start
Answers and Replies
SteamKing
Staff Emeritus
12,798
1,666
The best place to start is to read the problem statement carefully.
There are some directions about setting up the problem. Have you followed these instructions?
It might help you to draw a sketch of the frame as directed. Treat each of the members as a bar, and the bars are connected to each other by pins.
reply
I understand a little bit, someone told me that I have to calculate the weight of the bars first, and I don't really know how to do it, but if someone can tell me how to do that maybe I can do the problem.
SteamKing
Staff Emeritus
12,798
1,666
The bars have a mass/unit length of 4 kg/m. If a bar is 4 m long, what is its mass?
Related Threads for: Statics Problem Help
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
