Homework Help: Statics Problem
  1. May 31, 2013 #1
    Two cables are tied together at C and loaded as shown. Determine the range of values of P for which both cables remain taut.
    2. Relevant equations
    [itex]\Sigma F_x=0[/itex]
    [itex]\Sigma F_y=0[/itex]
    3. The attempt at a solution
    [itex]\Sigma F_x=\frac{ 4 }{ 5 }*P-\frac{ 600 }{ 650 }*T_{AC}=0[/itex]
    [itex]\Sigma F_y=\frac{ 250 }{ 200 }*T_{AC}+T_{BC}+\frac{ 3 }{ 5 }*P-480=0[/itex]
    I am ending up with 2 equations and 3 unknowns. How can I eliminate the variables?
  3. May 31, 2013 #2
    rock.freak667
    You'll need to take moments about a point then. Try about point A.
  4. May 31, 2013 #3
    My knowledge on this is a bit rusty. Taking the moment about point A, I know for BC I would have: 600*T_(BC)
    I am not sure about the others, but here is my guess: [itex]ƩM_A=0.6*T_{BC}+0.6*(600/650)*T_{AC}-0.6*480+0.6*(2/5)*P=0[/itex]
    Is this correct?
  5. May 31, 2013 #4
    haruspex
    You need to use the critical condition that the cables remain taut. If P is too small for that, which cable will go slack? What if P is too great?
  6. May 31, 2013 #5
    Setting P=0, it seems that cable AC will go slack. I am not sure about if P is too great. It looks like it would be BC. I am still confused.
  7. May 31, 2013 #6
    haruspex
    You may be confused, but you're getting there :smile:. So what equation do you get for BC going slack?
  8. May 31, 2013 #7
    This is where I'm confused. I took an arbitrarily large number and set it equal to P. Plugging this into both equations, T_(BC) becomes a large negative value. Not sure if I'm doing this correctly.
  9. May 31, 2013 #8
    Your coefficient of TAC in the y force balance is incorrect. It should be 250/650.
    Solve this pair of equations for TAC and TBC as a function of P. Make a graph or a table of TAC and TBC versus P. Each of the cables will go slack if the tension in the cable is less than zero. Find out the range of P that makes this happen for each of the cables. For example, you can immediately see from the x- force balance that cable AC will go slack if P is less than zero.
  10. May 31, 2013 #9
    haruspex
    You don't need to try plugging in an arbitrary value for P. As P increases from 0, what will TBC be at the point where BC goes slack?
    (Also, note the correction Chestermiller mentions to your Fy equation.)
  11. May 31, 2013 #10
    Thank you!! I did this and got the correct answer. Here is what I did:
    I rearranged the equations like this:
    [itex]T_{AC}=P*\frac{4}{5}*\frac{650}{600}[/itex]
    [itex]T_{BC}=480-\frac{250}{650}*T_{AC}-\frac{3}{5}*P[/itex]
    Then I created these tables:
    Since T_BC is positive at P=514 and negative at P=515, 514 must be the maximum value of P.
    Is this the only way to do this problem? Is there any easier method that takes less time?
  12. May 31, 2013 #11
    haruspex
    Yes - answer my question in post #9.
  13. Jun 1, 2013 #12
    TBC would be 0 where BC goes slack. But then what do I set TAC equal to?
  14. Jun 1, 2013 #13
    haruspex
    With TBC = 0 you now have two equations and two unknowns. Solve them.
  15. Jun 1, 2013 #14
    Ah, right, I wasn't thinking :redface:
    Indeed this yields the same answer. Thanks!
Have something to add?
Draft saved Draft deleted
