Stationary Waves: Equations for Standing Waves
In summary, the four equations given can all form stationary waves, but only equations 1 and 3, and equations 2 and 4, can form standing waves. This is because the direction of the wave is determined by the sign of the quantity (coefficient of w/coefficient of x) and in equations 2 and 3, this sign is the same, resulting in waves traveling in the same direction. To avoid confusion, it is helpful to use the method of finding the sign of dx/dt to determine the direction of the wave.
Abhishekdas
208
Stationary waves...
Which of the following equations can form stationary waves...
1. y=Asin(wt-kx)
2. y=Acos(wt-kx)
3. y=Asin(wt+kx)
4. y=Acos(wt+kx)
Answer is 1,3 and 2,4 which is obviously correct...But why can't other combinations be possible as long as they are traveling in opposite directions (like 2 and 3)?
And you can standing waves be formed by waves of different amplitudes?
2 & 3 are traveling in the same direction :)
No... they are opposite... 2 is in the +ve x direction and 3 is in the -ve x direction...
Why do you think so? (your explanation)
Hint: The functions are not same...one is sine and the other is cosine :wink:
The direction of wave is determined by the sign of the quantity (coefficient of w/coefficient of x) it its is positive then the wave is traveling in -ve x direction and vice versa...That is my explanation...
As long as the function defining wave remains the same!
You can write 2. y=cos(wt-kx) as y=sin(π/2-wt+kx)=sin(w't+kx)
But how can one write it as sin(w't+kx)...w has to remain same and has to be positive...
And ya...how does it explain why 2 and 3 can not form a standing wave?
My mistake.
Its y=sin(π/2-wt+kx)=sin(Φ-wt+kx). Compare this with y=sin(kx+wt).
2. and 3. are traveling in the same direction. They can't produce a standing wave.
I am still not clear..how are they traveling in the same direction? if the velocities have opposite sign...
Sorry for the late reply.
Yes you were correct earlier, 2 and 3 form standing waves. I was confused in the direction too. You can check the sign of kx if the function remains same, like y=Asin(wt-kx) and y=Asin(wt+kx). Note that if you write y=Asin(wt-kx) as y=-Asin(kx-wt), it does not change the direction, but reflects the wave w.r.t x-axis.
So to avoid the confusion, there is a fundamental method. If f(x,t) is the function representing a wave, then df/dt=0 (if wave shape remains constant, which is usually the case). Find out the sign of dx/dt from each equation and compare :smile:
What is a stationary wave?
A stationary wave, also known as a standing wave, is a type of wave where the individual particles of the medium do not move, but instead oscillate back and forth in a fixed position. This is caused by the interference of two waves with the same frequency and amplitude traveling in opposite directions.
What is the equation for a stationary wave?
The equation for a stationary wave is: y(x,t) = Asin(kx)cos(ωt) or y(x,t) = Acos(kx)sin(ωt), where y is the displacement of the particle, x is the position, t is the time, A is the amplitude, k is the wavenumber, and ω is the angular frequency.
What are the main properties of stationary waves?
There are three main properties of stationary waves: nodes, antinodes, and standing wave ratio. Nodes are points on the wave where there is no displacement and the amplitude is zero. Antinodes are points on the wave where the displacement is maximum and the amplitude is at its peak. Standing wave ratio is the ratio of the amplitude at an antinode to the amplitude at a node.
What are some real-life applications of stationary waves?
Stationary waves have many real-life applications, including musical instruments such as stringed instruments and organ pipes, where the standing waves produce different pitches and sounds. They are also used in medical imaging techniques like ultrasound, where sound waves are reflected off structures in the body to create images.
What factors affect the formation of stationary waves?
The formation of stationary waves is affected by several factors, including the frequency and amplitude of the waves, the medium through which the waves are traveling, and the boundary conditions of the system. These factors can change the shape and size of the standing wave and the positions of the nodes and antinodes.
