Homework Help: Statistical Mechanics: Ideal Gas
  1. Apr 11, 2009 #1
    Using the microcanonical ensemble, find the entropy for the mixing of two ideal gases, but we need to compute all at once instead of separately for each gas and adding the two.
    2. Relevant equations
    [tex]\Omega(E)=\int_{H<E}d\overline{p}d\overline{q}[/tex]
    [tex]S(E,V)= k_{B} (Ln[\Omega(E)])[/tex]
    3. The attempt at a solution
    Now we did an N particle ideal gas in class. I feel this is very similar, but I have the
    Hamiltonian
    [tex] H = \stackrel{N_{a}}{\sum}} \frac{p^{2}_{i}}{2 m_{a}} + \stackrel{N_{b}}{\sum}} \frac{p^{2}_{j}}{2 m_{b}} [/tex]
    Well, since it is independent of the position, then before mixing
    [tex]\Omega(E)=V^{N_{a}}_{a}V^{N_{b}}_{b} \int_{H < E} \frac{\stackrel{N_{a}}{\prod}d\overline{p}_{i}}{h^{3N_{a}}}\frac{\stackrel{N_{b}}{\prod}d\overline{p}_{j}}{h^{3N_{b}}}[/tex]
    The remaining integral should be a [tex]3(N_{a}+N_{b})[/tex]-dimensional hypersphere w/ a radius of [tex]\sqrt{2 m_{a} m_{b} E}[/tex]
    The rest should fall in place, but I wondering if it is that straightforward.
Draft saved Draft deleted
