Homework Help: Statistical Physics
  1. Apr 3, 2010 #1
    Consider a thermal system at temperature T where the probability of finding the system
    in a microstate r with energy Er is given by an arbitrary probability distribution pr that is
    normalised so that Sum(pr) = 1.
    Let kB denote Boltzmann’s constant and consider the Boltzmann distribution
    [tex]p^{B}_{r}= \frac{e^{-\beta E_{r}}}{Z}[/tex]
    where Z is the partition function and beta = 1/kB.T
    Now we want to compare an arbitrary probability distribution
    [tex]p_{r}[/tex] with the Boltzmann distribution [tex]p^{B}_{r}[/tex]. Let
    [tex]S = - k_{B} \sum p_{r} ln p_{r}[/tex] denote the entropy of the system characterised by an arbitrary probability distribution and
    [tex]S^{B} = - k_{B} \sum p^{B}_{r} ln p^{B}_{r}[/tex]
    denote the entropy of the system characterized by the Boltzmann distribution. By adding and subtracting
    [tex]k_{B} \sum p_{r} ln p^{B}_{r}[/tex]
    we can write:
    [tex]S - S^{B} = k_{B}\sum (-p_{r} ln p_{r} + p_{r} ln p^{B}_{r} - p_{r} ln p^{B}_{r} + p^{B}_{r} ln p^{B}_{r} )[/tex]
    Assuming that the two probability distributions pr and pBr yield the same mean energy <E>, show that
    [tex]S - S^{B} = k_{B} \sum p_{r} ln \frac{p^{B}_{r}}{p_{r}} [/tex]
    2. Relevant equations
    [tex]<E> = \sum p_{r} E_{r} [/tex]
    3. The attempt at a solution
    [tex] <E> = \sum p_{r} E_{r} = \frac{1}{Z} \sum E_{r} e^{-\beta E_{r}}[/tex]
    I was thinking you can cancel the summation and conclude the arbitrary distribution = the boltzmann distribution? I would then use this result and show the last two parts of the S - SB expression = 0.
Draft saved Draft deleted
