Probability of Picking an Ace from 47 Cards
  • Thread starter lazyp
  • Tags
    Stats
In summary, the probability of picking an ace from 47 cards is 4/47 or approximately 0.0851. This is calculated by dividing the number of aces in the deck (4) by the total number of cards (47). The probability remains the same regardless of previous picks, as each pick is an independent event. Shuffling the deck does not affect the probability as long as the number of aces and total number of cards remain the same. The only other factor that can affect the probability is if the deck is not a standard deck of playing cards.
lazyp
Pick one card from a deck, then throw it away. Now pick another card from the remaining 51 cards. What is the probability that card is an Ace?
Pick 5 cards from a deck and throw them away without looking at them. Now pick another card from the remaining 47 cards. What is the probability that card is an Ace?
Is this a homework question?
When doing probability problems the best thing to do is to get a concise definition of the state space.
For example in the first experiment you pick one card and since there is 52 cards the probability of picking an ace in that experiment is 4/52 = 1/13
With the second experiment you will have probabilities that are dependent on the results of your experiment. If you pick up an ace in the first then there will be three aces in the second experiment. If there is no ace in the first trial then there there is one less "non-ace" card.
With these hints, can you formulate the probabilities of P(Get an ace | picked up an ace in first experiment) and P(Get an ace | No ace in first experiment)?
Yea i understand what you mean, but is the final answer to the 1st question one single probability or are there two answers(depending on whether or not an ace is picked in the 1st draw)?
You will end up with one final probability (answer) but you will have to consider all cases and that includes handling both of the conditional cases specified above.
Since the two cases are disjoint (mutually exclusive), you have to find both of the probabilities and add them together to get your final answer.
Moderator's note: thread moved to Homework & Coursework Questions from Set Theory, Logic, Probability, Statistics.
Please let the OP show an attempt at solving the problem before offering further hints and help.
Regards,
Redbelly98
1. What is the probability of picking an ace from 47 cards?
The probability of picking an ace from 47 cards is 4/47 or approximately 0.0851.
2. How did you calculate the probability of picking an ace from 47 cards?
To calculate the probability, you take the number of aces in the deck (4) and divide it by the total number of cards in the deck (47).
3. Is the probability of picking an ace from 47 cards affected by previous picks?
No, the probability of picking an ace from 47 cards remains the same regardless of previous picks. Each pick is an independent event and does not affect the probability of future picks.
4. How does the probability of picking an ace from 47 cards change if the deck is shuffled?
The probability of picking an ace from 47 cards does not change if the deck is shuffled. As long as the number of aces and total number of cards remain the same, the probability will remain constant.
5. What other factors can affect the probability of picking an ace from 47 cards?
The only other factor that can affect the probability is if the deck is not a standard deck of playing cards. For example, if the deck has more or less than 4 aces, the probability will be different.
  • General Math
