Steam Engine
  • Thread starter WhoThat3
WhoThat3
Info on object:
Mass = 10kg
Radius = 0.20m
Lenght of spouts = 0.10m above surface of sphere. (The two spouts can be considered massless.)
The sphere is hollow and looks like this. The pressure inside is 1.5 atm and the pressure outside is 1.0atm.
http://upload.wikimedia.org/wikipedia/commons/3/3e/Aeolipile_illustration.JPG [Broken]
a) Find moment of inertia (found)
b) What is the angular acceleration of the container? Take the area of the spouts to be circles of radius 0.010m.
Not sure, but I used Pascals principle.
Bernoullis came to mind, but I doubt it.
a) I = 2/3*MR^2 = 0.26...
I = 0.27
b) Pout = Pin(not sure since this is not true since pressure inside is 1.5atm pressure outside is 1.0atm)
Fout/Aout = Fin/Ain
Fout/(pi*r^2) = 1.5atm/(pi*r^2)
Fout=1.5atm
1.5atm = 151950 N/m^s
This is a tangental force.....
F=mra (a is alpha, angular acceleration; r+lenght of spouts)
a=F/(mr)
a=50650???
Does not look right
I am a bit confused on what to use for part b of this question. I do not think that my result is accurate. Any advice would be appreciated or any pointers.
Thanks:smile:
edit: Also anyone know how to find the energy stored by the steam inside the container??
Answers and Replies
Doc Al
Mentor
45,425
1,876
Since the inside pressure is greater than the outside pressure, there's a net outward force. Find that force and the resulting torque on the sphere.
WhoThat3
Hmm, ok I will try to find it, so I guess what I did was wrong then. Well cool, I'll post if I come across any other problems.
WhoThat3
Sorry for bringing this up again, but I cant find the force due to the pressures. Can someone tell me how to find it please, no need for a blunt answer, but a formula to use would do just as well? After this I am pretty sure I can finish the problem on my own.
Doc Al
Mentor
45,425
1,876
What's the definition of pressure?
WhoThat3
pressure: Force/Area
Doc Al
Mentor
45,425
1,876
Exactly. Note that they give you the area of the spouts. You have the net pressure and the area, so find the force exerted at each spout by the escaping steam.
WhoThat3
Ohh, ok so the force would be,
F = P*A
F = 1.5*(pi*r^2)
F = 0.00471
So now for torque:
t = r * F
t = (0.2m+0.1m) * 0.00471
t = 0.200047
Lastly
sigma t = I*a
a = sigma t/I
a = 0.108025
OK this sounds like a more reasonable answer thanks for the help. Now I only need to find the energy inside the container...sigh =)
Doc Al
Mentor
45,425
1,876
F = P*A
F = 1.5*(pi*r^2)
F = 0.00471
The net pressure is not 1.5 atm--use the difference in pressure between inside and outside. But convert to standard units in order to find the force.
Would I need to double this since it does occur in two place but pushes in the same direction?
Both spouts are identical and exert the same torque. So figure it out for one and then double it.
WhoThat3
Ohh ok thanks, I fixed it, now to find the energy by the steam...would you help me with that as well?
WhoThat3
I guess no one knows this, well thanks for the help on the other parts guys =)
Suggested for: Steam Engine
  • Last Post
  • Last Post
  • Last Post
  • Last Post
