Steam requirement calculation
In summary, steam requirement calculation is the process of determining the amount of steam needed to heat a system or process to a desired temperature. It is important for maintaining temperature and pressure levels, optimizing energy usage, and preventing equipment damage. Factors such as system type, heat requirements, and steam source efficiency are considered in the calculation, which is typically performed using equations and formulas. External factors can also affect the calculation, so regular reassessment and adjustments are necessary for optimal system performance.
punitdubey21
i need to calculate steam required to remove moisture content from the paper .
low pressure steam: 2.7kg/cm2
i have calculated total water to be evaporated : 3500kg/hr
machine speed is 335 mt/min
gsm of paper:64gsm
deckle width;310 cm
Q=ML
Q is the total heat required to evaporate water
M= mass flow rate of steam
L=latent heat of vaporization
see i have calculated total water to be evaporated based on moisture content . but not getting how to calculate heat required since 1 kg of water required 2257kj/kg to convert it into steam .
i m very confused what to do . . .
To calculate the steam required to remove moisture content from the paper, we will need to use the following formula:
Q = ML
Where:
Q = Total heat required to evaporate water (in kJ/hr)
M = Mass flow rate of steam (in kg/hr)
L = Latent heat of vaporization (in kJ/kg)
First, we need to determine the mass flow rate of steam (M). We can do this by dividing the total water to be evaporated (3500 kg/hr) by the latent heat of vaporization (2257 kJ/kg):
M = 3500 kg/hr / 2257 kJ/kg = 1.55 kg/hr
Next, we need to determine the latent heat of vaporization (L). This can be found in a steam table or by using the following formula:
L = 2257 - 1.88(Tsat - 100)
Where:
Tsat = Saturation temperature of steam (in °C)
For low pressure steam at 2.7 kg/cm2, the saturation temperature is approximately 133.8°C. Therefore:
L = 2257 - 1.88(133.8 - 100) = 2257 - 63.5 = 2193.5 kJ/kg
Now, we can plug these values into our formula to calculate the total heat required (Q):
Q = (1.55 kg/hr)(2193.5 kJ/kg) = 3402 kJ/hr
Therefore, the total heat required to evaporate 3500 kg/hr of water at low pressure steam of 2.7 kg/cm2 is 3402 kJ/hr. This information can now be used to determine the appropriate steam supply and ensure efficient removal of moisture from the paper. I hope this helps. Good luck with your calculations!
What is steam requirement calculation?
Steam requirement calculation is the process of determining the amount of steam needed to heat a system or process to a desired temperature. It takes into account factors such as the type of system, the amount of heat required, and the efficiency of the steam source.
Why is steam requirement calculation important?
Steam requirement calculation is important because it ensures that the right amount of steam is supplied to a system, which is crucial for maintaining temperature and pressure levels. It also helps to optimize energy usage, reduce costs, and prevent equipment damage or failure.
What factors are considered in steam requirement calculation?
The factors considered in steam requirement calculation include the type of system or process, the amount of heat required, the efficiency of the steam source, the desired temperature and pressure, and any heat losses or inefficiencies in the system.
How is steam requirement calculation performed?
Steam requirement calculation is typically performed using mathematical equations and formulas, which take into account the various factors mentioned above. These calculations may be done manually or with the help of computer software.
Can steam requirement calculation be affected by external factors?
Yes, external factors such as changes in ambient temperature, variations in steam source efficiency, or fluctuations in demand for heat can affect the steam requirement calculation. It is important to regularly reassess and adjust the calculations to ensure optimal performance of the system.
10K
10K
  • Mechanical Engineering
