Mass Function of Stars in Globular Clusters - 600 M Sun
In summary, the conversation discusses the distribution of stars in a globular cluster and their mass function. It also presents a request to show the necessity of an upper limit in the mass distribution to avoid infinite cluster mass, calculate the limit for a total mass of 600 solar masses, and determine the cluster's bolometric luminosity in solar units and corresponding absolute magnitude. The solution involves using definite integrals to find the upper limit and calculate the bolometric luminosity and absolute magnitude based on the given mass and luminosity equations.
RHK
64
Stars in a globular cluster are distributed as a mass function of: [itex]\phi(M)=K M^{-2}[/itex], such that [itex]dN=\phi(M) dM[/itex] is the stars number in the infinitesimal mass interval. Masses are between a lower limit [itex]M_{inf}=0.3 M_{sun}[/itex] and an upper limit [itex]M_{sup}[/itex], unknown.
The constant K is equal to [itex]200 M_{Sun}[/itex].
Let's assume also that the relation between the bolometric luminosity and the stars masses is [itex]L(M)=L_{Sun}(\frac{M}{M_{Sun}})^{3.5}[/itex]. Requests:
(i) to show the necessity of the existence for the upper limit in the mass distribution, to avoid that the cluster mass diverge toward infinite.
(ii) to calculate the value of such limit so that the total mass of the cluster is [itex]600 M_{Sun}[/itex];
(iii) to calculate the cluster bolometric luminosity in solar units, and the corresponding absolute magnitude.
EDIT: the absolute bolometric magnitude for the Sun is given in the exercise text: [itex]m_{sun}=4.75[/itex]
[itex]M_{TOT}=\int_{M_{inf}}^{M_ {sup}} M \phi(M) dM[/itex]
[itex]M_{TOT}=\int_{M_{inf}}^{M_ {sup}} K M^{-1} dM = K log M[/itex]
Is it the right way?
Can i have a hand please?
Your solution is a good start, but it has a problem. On the one hand, it looks like an indefinite integral because the limits of integration don't appear on the right hand side. On the other hand, if it were an indefinite integral, it would need a constant of integration to go along with it. The way to go here is definite integral because of the limits of integration in the middle term of your solution. Once you do that, I think the answer to part (i) will pop out at you.
Yes, ok. I wrote a definite solution just to have some feedback...
I will do that and then i will post it to have other help for the other parts.
Thanks
Well, the first two points are quite straightforward:
[itex]M_{TOT}= K log \frac{M_s}{M_i}[/itex],
so the existence of the upper limit is imposed from the otherwise divergent result.
Imposing [itex]M_{TOT}= 600 M_{Sun}[/itex], it's easy to find Msup=[itex]300 M_{Sun}[/itex], that is not so realistic.
But i can not proceed for the third point...
You are right, it is not realistic. 3 or 4 such stars would be the whole cluster and that is no cluster. You are assuming that the log is base 10. However, the formula you are using for the integral uses a different base.
That is right!
It was suspect, indeed.
Any suggest for the third point too?
What work have you done so far on part (iii)?
None: i can't handle it...
It's a rule here. we're not allowed to help you until you take the first step. Surely you have something you can show us.
Maybe: [itex]L_{bol}=\int L(M) dM = \int L_{Sun} (\frac{M}{M_{Sun}})^{3.5} dM[/itex]
so the bolometric luminosity in solar unit is
[itex]\frac{L_{bol}}{L_{Sun}}=\frac{1}{M_{Sun}^{3.5}} \frac{M^{4.5}}{4.5}[/itex]
where M is MTOT.
Is this plausible?
I see a couple of problems with this solution. For one thing, you have not taken into account the number of stars having a given luminosity. This shouldn't be hard to do though since you know the luminosity in terms of mass and you sort of know how many stars are of a given mass. Another problem is that you have once again taken an indefinite integral (without the constant of integration) when what is wanted is a definite integral.
If i understand your suggestion, the right integral is:
[itex]L_{bol}=\int_{M_{inf}}^{M_{sup}} L(M) \phi(M) dM[/itex]
This make more plausible the solution, indeed.
But i wait further confirms to proceed with calculations.
This is correct. It is instructive to compare this formula to the one given as a relevant equation in the OP.
I am taking my son to basketball practice now. Perhaps someone else can pick up from here. It seems there isn't much left to do.
Thanks a lot!
From the right integral it's possible to find the bolometric luminosity in solar unit.
Then the absolute magnitude is:
[itex] m_{bol} = -2.5 \frac{L_{bol}}{L_{sun}} + m_{sun}[/itex] where [itex]m_{sun}[/itex] is the absolute bolometric magnitude for the Sun, and it's given in the exercise text [itex]m_{sun}=4.75[/itex]
What is the "Mass Function" of stars in globular clusters?
The Mass Function of stars in globular clusters refers to the distribution of stellar masses within a globular cluster. This can provide valuable information about the formation and evolution of these clusters.
Why is the "Mass Function" of stars in globular clusters important to study?
Studying the Mass Function of stars in globular clusters can help us understand the processes that led to the formation of these clusters and the evolution of their stars. It can also provide insights into the dynamics and interactions between stars within the cluster.
What is the significance of a "600 M Sun" star in a globular cluster?
A 600 M Sun star in a globular cluster is considered a very massive star, as the average mass of stars in globular clusters is around 0.8 M Sun. This means that it can have a significant impact on the dynamics and evolution of the cluster, and studying its properties can provide valuable information about the cluster as a whole.
How is the "Mass Function" of stars in globular clusters determined?
The Mass Function of stars in globular clusters is determined by studying the luminosity and mass of stars within the cluster. This can be done through observations using telescopes, as well as through simulations and theoretical models.
What can the "Mass Function" of stars in globular clusters tell us about the age of the cluster?
The Mass Function of stars in globular clusters can provide insights into the age of the cluster, as the distribution of stellar masses can change over time due to stellar evolution and interactions. By studying the Mass Function, scientists can estimate the age of the cluster and track its evolution over time.
  • Astronomy and Astrophysics
