1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Stick thrown in air
  1. Nov 17, 2008 #1
    A student throws a stick of length L up in the air. At the moment the stick leaves his hand, the speed of the stick's end is zero. The stick completes N turns as its caught by the student at the initial release point. Show that the height to which the centre of mass of the stick rose is [tex]\pi NL/4[/tex]
    3. The attempt at a solution
    All that I can make out of the problem is that t if the velocity of the centre of mass of the stick was v then by energy conservation the centre of mass of the stick would have risen by [tex]v^{2}/2g[/tex]
    I cannot make out what can I do with that N and all. Help me please.
  3. Nov 17, 2008 #2
    tiny-tim
    Hi ritwik06! :smile:
    The way to approach a question like this is to start:
    "Assume the velocity of the two ends are v and 0, vertically …",
    and then calculate both the maximum height and the number of turns. :wink:
  4. Nov 17, 2008 #3
    I tried this.
    Assuming the velocity of the two ends are v and 0
    Using conservation of angular momentum:
    mvL/2=I [tex]\omega[/tex]
    then 0.5 I [tex]\omega^{2}[/tex]=mgh
  5. Nov 17, 2008 #4
    Redbelly98
    Staff Emeritus
    I think you'll also need the time taken to reach the maximum height. And from that figure out the time taken to come back down as well.
  6. Nov 18, 2008 #5
    tiny-tim
    exactly what it says on the box! …
    (have an omega: ω and a pi: π and a squared: ² :wink:)
    uh-uh … "conservation of angular momentum" means exactly what it says on the box!
    the angular momentum will carry on the same, no matter where the stick goes (unless there's a torque, which there isn't … the weight acts through the c.o.m) …
    so this is two separate problems …
    for the height you can ignore the angular momentum, and for the angular momentum you can ignore the height. :biggrin:
Similar Discussions: Stick thrown in air
  1. Stick thrown in air (Replies: 4)
Loading...
