Solving a Stochiometry Question: 2Li + F2 --> 2LiF
  • Thread starter SCGirl
In summary, after the reaction is complete, there will be lithium fluoride present. To determine the amount of lithium fluoride formed, the molar mass of fluorine (F2) should be used, but not for lithium which is monoatomic. This type of question should be posted under the Homework & Coursework forums.
SCGirl
A 15-g sample of lithium is reacted with 15 g of fluorine to form lithium fluoride: 2Li + F2 --> 2LiF. After the reaction is complete, what will be present?
I think I start by dividing 15 g by the molar masses, but is the molar mass
2 x amu of Li and 2 x amu of F?
Thanks
help is hereeeee...
i think you have to first find out what the limiting reactant is. and then use that amount to see how much lithium fluoride forms.
hope this helps :biggrin:
Thanks
Correct for fluorine, because it is made up of diatomic molecules (hence, F2), but not lithium, which is monoatomic.
PS: From the next time on, such questions should be posted under the Homework & Coursework forums found near the top of the main page.
1. How do you determine the limiting reactant in a stochiometry question?
The limiting reactant in a stoichiometry question is the reactant that will be completely consumed first, limiting the amount of product that can be formed. To determine the limiting reactant, you must first convert the given amounts of each reactant to moles. Then, using the coefficients in the balanced equation, calculate the moles of product that would be formed if each reactant were to completely react. The reactant that produces the least amount of product is the limiting reactant.
2. How do you calculate the amount of product formed in a stochiometry question?
To calculate the amount of product formed in a stoichiometry question, you must first determine the limiting reactant. Then, using the mole ratio between the limiting reactant and the product, calculate the moles of product that would be formed. Finally, convert the moles of product to the desired units using the molar mass of the product.
3. What is the difference between theoretical yield and actual yield?
The theoretical yield is the amount of product that can be formed based on the stoichiometry of the reaction, assuming 100% efficiency. The actual yield is the amount of product that is obtained in a real-world experiment. The difference between the two is known as the percent yield, which can be calculated by dividing the actual yield by the theoretical yield and multiplying by 100%.
4. How do you account for excess reactants in a stochiometry question?
If there are excess reactants in a stoichiometry question, it means that one of the reactants will not be completely consumed in the reaction. To account for this, you must first determine the limiting reactant and the amount of product that would be formed based on the complete consumption of the limiting reactant. Then, subtract the amount of excess reactant from the amount of limiting reactant to calculate the actual amount of limiting reactant that was used in the reaction. Finally, use this amount to calculate the actual amount of product formed.
5. What is the purpose of balancing equations in a stoichiometry question?
Balancing equations in a stoichiometry question ensures that the reaction is represented accurately, with the correct ratios between reactants and products. This is important because the coefficients in a balanced equation represent the mole ratio between reactants and products, which is necessary for accurate calculations in a stoichiometry problem.
11K
