Stokes Theorem
For stokes theorem, can someone tell me why [tex]\hat{a} \bullet \vec{ds} = ds[/tex]? My notes say it's because they are parallel, but I'm not sure what that means.
Also to get things clear, Stokes theorem is the generalized equation of Green's theorem. The purpose of Stokes theorem is to provide a means of calculating the "flux" [not the curl- which is the tendency for a point to rotate], or the amount of given substance moving through a surface [in our case a 3dimensional].
THanks,
JL
Answers and Replies
Cyosis
1,495
Are you familiar with inner products. For vectors [itex]\vec{a},\vec{b}[/itex] the inner product, or dot product in this case, is given by [itex]\vec{a} \cdot \vec{b}=|\vec{a}|| \vec{b}|\cos\theta[/itex], with [itex]\theta[/itex] the angle between the two vectors. What is the angle between parallel vectors?
Yep, you can do a dot product between two vectors, or you can dot a vector to get the projection onto an axis.
Cyosis
1,495
Then do you understand now why [itex]\hat{a} \cdot \vec{ds} = ds[/itex] when they are parallel?
No haha, that's my question, but I'll try to think about it more.
Cyosis
1,495
It's a dot product. Write this dot product in the form I listed in post 2 then ask yourself what is the angle between two parallel vectors?
Ok, so it is:
[tex] \hat{a} _{n} \cdot \vec{ds}=| \hat{a} _n| |\vec{ds}|\cos \theta[/tex]
Cyosis
1,495
Yep that is correct. Now for my second question, what's the value of [itex]\theta[/itex] if those vectors are parallel? Secondly what is the length of [itex]\hat{a}[/itex]? If you don't know try to explain to me what [itex]\hat{a}[/itex] is.
[itex]\hat{a}[/itex] is the unit normal vector, thus it has been "normalized" (to a length of 1). If we set [tex]\theta = 0[/tex] then we get [tex]\vec{ds} = |ds| = ds[/tex]
But what if [tex]\theta[/tex] is not zero, then this is false. So it is not parallel in all conditions- this is part of the reason I am horrible with proofs.
Ohh, never mind. What I needed was to show that particular condition (which you helped me discover) was true- not whether it was always true. By having that condition being true, I can use this in the derivation of Stokes theorem.
Thanks,
JL
This would have helped a while back ago, \vec{ds}, \hat{a} _n are by definition parallel.
Related Threads on Stokes Theorem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
J
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
