Stokes' Theorem
Given c(t) = [cos t, sin t, 2 + sin (t/2)] where t [tex]\epsilon[/tex] [0, 2pi] and F(x,y,z) = (2-y + x2, x + sin y, [tex]\sqrt{}[/tex]z4+1) --- Find [tex]\int[/tex]F.dS over c(0, 2pi).
I've no idea how to do this... any help would be awesome! Thanks!
Answers and Replies
tiny-tim
25,836
251
Well, what does Stokes' Theorem say?
HallsofIvy
41,847
966
Actually, I see no reason to use Stoke's theorem. It looks like it should be relatively easy to integrate
[tex]\int_c F\cdot dc[/tex]
directly.
If c= [cos(t), sin(t), 2+ sin(t/2)], what is dc?
Stokes' Theorem says that [tex]\int[/tex]F.dr inside a boundary C = [tex]\int[/tex]curlF.dS over a surface S... but how can I use it here?
And is dc = (-sin t, cos t, cos (t/2)/2) ??
tiny-tim
25,836
251
Stokes' Theorem says ... but how can I use it here?
What is curlF here? :smile:
Curl F is 3 k. I'm having trouble figuring out dS... I know for [tex]\int[/tex]curlF.dS I need a surface with the given boundary curve for dS... but I'm stuck there.
HallsofIvy
41,847
966
The reason I suggested NOT using Stoke's theorem but integrating directly on the path is that when [itex]\theta= 0[/itex], [itex](cos(\theta), sin(\theta), 2+ sin(\theta/2))= (1, 0, 2)[/itex] and when [itex]\theta= 2\pi[/itex], [itex](cos(\theta), sin(\theta), 2+ sin(\theta/2))= (1, 0, 1)[/itex]. This is NOT a closed path and so Stoke's theorem cannot be used.
For some reason, perhaps having just waked up, I was thinking "cosine" instead of "sine". Yes, they are the same point, yes, this is a closed path.
But if the end points of the curve are the same, isn't that the definition of a closed curve?
tiny-tim
25,836
251
hi calculus-stud! :smile:
(I make it 2k … have you copied F wrong? :confused:)
think … what is the flux of a (0,0,3) field through any closed curve? :wink:
(and yes, it looks closed to me too)
Yeah it should be F = (-2y + x2....) sorry. So, curl is 3k.
The flux is zero? So, we don't really need to integrate or Stokes' theorem here?
tiny-tim
25,836
251
(thanks for the pm)
calculus-stud said:
The flux is zero?
no
what would be the flux of a (0,0,3) field through, for example, a rectangle or an ellipse in the z = 0 plane? :wink:
Hey, umm, I'm kinda lost here. Can you give some more clues?
Ok, does it have to do with the orientation of the curve? I'm really stuck here ... any hints?
tiny-tim
25,836
251
what curve? :confused:
this is the integral of a vector going through a surface
Oh right, sorry... but then what is the surface? I'm so lost... I thought you were asking for flux of the vector field through any closed curve...
tiny-tim
25,836
251
what's the flux of (0,0,3) going through the horizontal rectangle (0,0,0) (0,2,0) (2,2,0) (2,0,0) ?
or through the horizontal circle, radius r centre (0,0,0) ?
Dick
26,263
619
Let me add another hint to tiny tim's hint. Imagine water flowing through a circular pipe at uniform speed v. If you take a flat disc cross-section perpendicular to the flow it's easy to compute the flux through the disc using stokes. If you take a more complicated wiggly cross section of the pipe, it could be much harder to compute the flux through that using stokes. But you don't have to. It will have the same flux as the easy cross section. Do you see why?
Related Threads on Stokes' Theorem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
J
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
