Stopping distance of a car.
In summary, the question is asking whether a car, traveling at a constant speed of 18ms^-1 and then applying brakes with a force of 3600N, would have a larger, smaller, or the same stopping distance if it were moving down a hill at the same speed and applying the same braking force. The answer depends on the forces acting on the car, which are the normal force and the friction force. The friction force is affected by the coefficient of friction between the tires and the road, and the normal force is lower on the hill, resulting in a lower maximum friction force. This means that the stopping distance would be longer for the car on the hill. Additionally, the brakes on the car on the hill would have
Kieranlavelle
A car is moving along a flat road at a constant 18ms^-1 it then applies the breaks with a force of 3600N
If this car is then moving down a hill at 18ms^-1 the same breaking force is applied is the cars stopping distance larger or smaller or the same?
Eκ = 1/2 M V^2
I said the same as the stopping distance is proportional to the Kinetic energy of the car is the thinking distance is not relevant so as the KE of the car is the same I assumed the stopping distance would be the same.
I then asked by brother who is rather good at maths but did not take physics and he was a bit indecisive and said it depends on how it was being marked. Can you guys shed any light on this?
Ask yourself... What are the forces acting on the car and are they the same in both cases? Draw two free body diagrams.
I am well aware of the component of the weight down the slope but for some reason still placed the same distance as my answer.
I've no idea why you think it would be the same. The car on the hill has to loose both KE and PE via the brakes.
I'm not sure what your brother was thinking about either. The maximum friction force that can be applied depends on the coefficient of friction between tyre & road and the normal force. The normal force is lower for the car on the hill so the maximum friction force would be lower. However the problem statement says that both cars manage to apply the same friction force so this effect isn't a factor.
In any case it would also increase the stopping distance of the car on the hill. I can't think of any reason way the stopping distance would be longer for the car on the flat so your brothers comment doesn't make sense to me. Sorry.
Sorry if I explained this poorly, my brother says the stopping distance is longer on the hill and the only thing that changes is the gradient of the slope and the question only accounts for the breaking force and not the friction of the tyres. if you want to know how basic this question is it was for an a level question.
Hi Kieranlavelle
Just forget the formulas and hop on a bike
Try to go uphill and see how easier or harder it is to stop your bike than on a flat road or a downhill road.
This should give you the intuition toward the right answer, which should in turn guide you to how to explain why this is so.
Once this is clear, well the problem as given has some room for improvement in terms of how it could be stated, meaningless values given, meaningful values not given (if you want to consider how a car given real life conditions is having a constant speed on a flat road and how this is translated in the downhill case etc.)
He is correct.
What would happen if the hill was very very step? Let's say it's approaching a vertical drop and the car weighs 360kg. The force of gravity acting down the hill would be almost f = ma = 360 * 9.8 = 3528N. The braking force acting up the hill is stated as 3600N. Subtract and you get the net force acting on the car...
3600 - 3528 = 72N
So the total force acting on the cars is:
On the flat: 3600N
On the hill: 72N
Fairly obvious which will slow down quicker and which will have the longest stopping distance.
If you want to think of it in terms of energy then as I pointed out earlier the brakes of the car on the hill have to dissipate both the PE and the KE where as the brakes on the flat only have to dissipate the KE.
As Oli4 points out your problem statement doesn't have enough info to calculate the exact stopping distance in each case.
Eκ = 1/2 M V^2
Was the slope sufficiently rough so that before the brakes were applied the car was traveling at a constant 18 ms-1 as with the flat surface? ie rough enought to provide sufficient friction other than form the brakes?
What factors affect the stopping distance of a car?
The stopping distance of a car can be affected by several factors including the speed of the car, the condition of the tires, the road surface, and the driver's reaction time. Other factors such as weather conditions and the weight of the car can also play a role.
Why is it important to understand the stopping distance of a car?
Understanding the stopping distance of a car is crucial for safe driving. It allows drivers to anticipate and react to potential hazards on the road, such as sudden stops or obstacles. It also helps drivers maintain a safe distance from other vehicles on the road, reducing the risk of accidents.
How can the stopping distance of a car be calculated?
The stopping distance of a car can be calculated using the formula: stopping distance = reaction distance + braking distance. The reaction distance is the distance the car travels while the driver reacts to a hazard, and the braking distance is the distance the car travels while braking to a complete stop. Both of these can be affected by the factors mentioned in the first question.
What is the average stopping distance for a car?
The average stopping distance for a car traveling at 60 mph is approximately 300 feet. However, this can vary depending on the factors mentioned above. It is important for drivers to always maintain a safe speed and distance to ensure they can stop in time if needed.
How can the stopping distance of a car be reduced?
The stopping distance of a car can be reduced by maintaining a safe speed, having good tire tread, and having quick reaction times. It is also important to regularly check and maintain the brakes, as well as being aware of road conditions and potential hazards. Defensive driving techniques can also help reduce the stopping distance of a car.
