Storage of Electromagnetic waves
In summary, the conversation discusses the possibility of storing electromagnetic waves for long-term energy storage. However, it is not feasible due to unavoidable losses and the difficulty of converting and storing the waves into another form of energy. The conversation also mentions the concept of storing waves in a cavity with reflective surfaces, but it is not a practical solution due to the quick dissipation of energy.
nilesh_pat
224
Is there any possibility of storage of electromagnetic waves ?
With regards
Nilesh.
Yes, but not for the purposes of long-term energy storage. The intensity of the wave and the time frame you can keep it 'stored' is small due to unavoidable losses.
Thank you sir for your reply. Please explain "unavoidable losses".
With regards,,
Nilesh
I'm not sure what to say. In any application where we use EM waves we have losses. There is no such thing as a perfect reflector, so any time an EM wave is reflected it loses energy.
Thank your sir. That means we are still not concern about the losses of EM waves or why waves observed by something. If it is observed it might we retrieve ?
With regards
nilesh
I'm sorry but I cannot understand your question.
Sir, As you replied in any application where EM waves are used we have losses. My point why we have losses. If the losses are recoverable or not.
With regards
Nilesh
It's not that the losses aren't recoverable. Some of them actually are. It's that if you already have losses, then you're better off just converting the light into a form of energy that can be stored without those losses in the first place. It's MUCH easier and cheaper to convert light into heat, electrical, chemical, or another source of potential energy than to try to store the light directly.
Ok Sir. Could be store any of frequency from AM to Satellite - ( 530 kHz to 12 GHz)
With regards
Nilesh
Sure, but only for a fraction of a second. That's how quickly you'll lose all of the energy if you don't convert the energy of the EM wave into something else that's easier to store.
With regards
Nilesh
A wave is a 'dynamic' phenomenon. The only way to 'store a wave' is to keep it inside a cavity of some sort with reflective surfaces. Such a cavity would have surfaces with finite resistivity and that would cause power to be dissipated very quickly.
An example: If you lost as little as 1% at each reflection and the radiation were kept in a space between two curved mirrors, separated by 3m (a simple example), in a second, there would be 108 reflections, producing 0.99 to the power of 108. Your calculator will not show you enough zeros to tell you how much of the original energy would be left.
Thank you sir.
Thank you sir.
FAQ: Storage of Electromagnetic waves
1. What is electromagnetic wave storage?
Electromagnetic wave storage refers to the process of storing electromagnetic waves, which are a type of energy that can travel through space in the form of waves. These waves are typically used for communication and can be stored in various forms, such as in the Earth's magnetic field or in electronic devices.
2. How are electromagnetic waves stored?
Electromagnetic waves can be stored through various methods, depending on the specific application. Some common methods include using antennas to store radio waves, using magnetic storage media for storing data in electronic devices, and using the Earth's magnetic field for long-term storage of low-frequency waves.
3. What are the benefits of storing electromagnetic waves?
Storing electromagnetic waves allows for efficient and reliable communication, as well as the ability to transmit and receive information over long distances. Additionally, storing electromagnetic waves can also be used for scientific research and exploration, such as studying the Earth's magnetic field or detecting distant objects in space.
4. Are there any risks associated with storing electromagnetic waves?
While there are no known health risks associated with storing electromagnetic waves, there are some concerns about potential interference with other electronic devices. It is important to properly regulate the storage and use of electromagnetic waves to avoid any potential negative effects.
5. How can we improve the storage of electromagnetic waves?
Researchers are constantly working on improving the storage of electromagnetic waves through advancements in technology, such as developing more efficient antennas and storage devices. Additionally, careful planning and regulation of the use of electromagnetic waves can also help improve storage methods.
