Store Solar Energy: Learn How to Charge Batteries with 20 2W Panels
In summary: Basically, you have two panels - one is doped with phosphor and boron, and when sunlight hits it, it kicks electrons off the other panel which then switches their charges. These panels are then connected to a wire in an outer circuit, which then sends the electrons to whatever device you want it to.
nascar
I have just purchased 20 2w solar panels, i am brand new at this kinda stuff but i am very very interested in how it all works. can anyone help me, or explain how its done basically i would like to be able to charge a battery with solar panels.. thanks ..
Likes arpit.v
Do you have more information, such as the voltage they produce? Solar panels, as far as I know are made from semiconductor material. The light frees up electrons which provide the current. The way they are made causes them to have diode like properties so the current can only flow in one direction.
Hi,
Here is an important tip on storing solar energy.
The idea is to capture the sun’s heat. Heat, unlike electric current, is something that industry knows how to store cost-effectively. For example, a coffee thermos and a laptop computer’s battery store about the same amount of energy.Solar thermal systems are built to gather heat from the sun, boil water into steam, spin a turbine and make power, as existing solar thermal power plants do — but not immediately. The heat would be stored for hours or even days, like water behind a dam.
Solar panels are relatively simple.
Solar panels are made out of 2 silicon panels (not to be confused with silicone) and a panel colored black.
The 2 silicon panels are "doped" with a certain atoms. One of the silicon panels are laced with Phosphor-atoms and the other with Boron-atoms. The one with Phosphor is then has more electrons than normal which makes the panel negatively charged because it has free negative charges. The Boron makes is so that the other panel has less electrons than normal which will make it positively charged because there are "holes" between the silicon atoms. These panels are called N-type silicon and P-type silicon (negative and positive silicon plates). The N-panel is then placed on top of the P-panel and the black panel is placed on top of the N-panel (the black panel is only there to increase the effect, since black attracts solar energy). When the N-panel touches the P-panel, the N-panel is then "hyped" and the free electrons tries to go over to the P-panel to fill the missing holes between the silicon atoms. The two panels then switch charges. The P-panel becomes negatively charged and the N-panel becomes positive (since the P-panel gains electrons and the N-panel looses electrons). When these two panels get "hyped" when they touch, they create a barrier which makes electrons unable to pass between the N-panel to the P-panel after they switch charges. Now you might ask, where does the solar energy comes into the picture? When the sun rays hit the black panel and the electrons are kicked away from the P-panel to the N-panel, which then again switches the charges, but after this second change, they can't go anywhere. This is why we have wires connected to the two panels, this way the electrons will be able to return to the P-panel. In the "outer"-circuit the electrons will deliver energy to which ever device the wires are connected. The sun energy have now become electric energy.
From the device, the electrons will go to the P-panel which will make it negative again, this way the process is restarted and will be able to go around and around almost indefinitely.
If you bothered to read that wall of text, then you know how solar panels work.
1. How do solar panels store energy?
Solar panels store energy by converting sunlight into electricity through photovoltaic cells. These cells consist of layers of silicon, which create an electric field when exposed to sunlight. The electric field then allows for the movement of electrons, generating electricity.
2. What type of batteries can be charged with solar panels?
Solar panels can charge various types of batteries, including lead-acid, lithium-ion, and nickel-cadmium batteries. The type of battery needed depends on the specific application and the amount of energy required.
3. How many solar panels are needed to charge a battery?
The number of solar panels needed to charge a battery depends on the size and capacity of the battery, as well as the amount of sunlight available. For example, a 100 Ah battery may require 10-12 2W solar panels to charge fully in a day.
4. Can solar panels charge batteries on cloudy days?
Yes, solar panels can still generate electricity on cloudy days, although the amount of energy produced may be reduced. The panels can still charge batteries, but it may take longer compared to a sunny day.
5. How long does it take to charge a battery with 20 2W solar panels?
The time it takes to charge a battery with 20 2W solar panels depends on the size and capacity of the battery, as well as the amount of sunlight available. On average, it may take 4-6 hours to fully charge a standard 12V battery with 20 2W solar panels.
  • Electrical Engineering
  • DIY Projects
  • Other Physics Topics
  • General Engineering
