Solving Strain Gauge Problem: Young's Modulus Calculation
In summary, we used the formula for gauge factor to calculate the strain in the bridge circuit, then used the given formula for stress to calculate the stress. Finally, we used the formula for Young's modulus to calculate the value for the material of the specimen.
bill nye scienceguy!
127
In a bridge circuit R1 is bonded to a cylindrical specimen of diameter 25.08mm. R4 is 160.1ohm, R3 is 2502.7ohm and R2 at balance is 2505.8ohm when the specimen is unloaded and 2511.7ohm when it is loaded with 50kN. the gauge factor of the strain gauges was 2.10. determine the value of young's modulus for the material of the specimen.
R1/R2=R4/R3
Vo=V/4(dR1/R1 - dR2/R2)
Vo=V/4.k.e where e is strain
stress= force/area = 50kN/pi(12.54x10^-3)^2
obviously all i need to do is derive the strain and then divide that into the stress calculated above but i really have no idea where to begin. the only relations aside from the simple ratio that i know for a wheatstone bridge circuit involve the input and output voltage which aren't given in the question. so how should i go about manipulating the resistances to work out the strain?
thanks!
Thank you for your question. To calculate the strain in this bridge circuit, we can use the formula for gauge factor:
k = (dR/R) / e
Where k is the gauge factor, dR is the change in resistance, R is the initial resistance, and e is the strain. We can rearrange this formula to solve for strain:
e = (dR/R) / k
In this case, we know that the gauge factor is 2.10 and we have the values for R1, R2, and R3. To calculate the change in resistance, we can use the ratio relationship between the resistances:
R1/R2 = R4/R3
Rearranging this, we get:
R1 = (R2/R3) * R4
Plugging in the values given in the problem, we get:
R1 = (2505.8/2502.7) * 160.1 = 160.2 ohm
Now, for the unloaded condition, we can calculate the change in resistance as:
dR = R1 - R2 = 160.2 - 2505.8 = -2345.6 ohm
And for the loaded condition, we can calculate the change in resistance as:
dR = R1 - R2 = 160.2 - 2511.7 = -2351.5 ohm
Plugging these values into the formula for strain, we get:
e = (-2345.6/160.2) / 2.10 = -0.6969 for the unloaded condition
e = (-2351.5/160.2) / 2.10 = -0.6993 for the loaded condition
Now, to calculate the stress, we can use the formula given in the problem:
stress = force/area = 50kN/pi(12.54x10^-3)^2 = 402.3 MPa
Finally, to calculate Young's modulus, we can use the formula:
E = stress/strain
Plugging in the values we calculated, we get:
E = 402.3 MPa / (-0.6969) = -577.5 GPa for the unloaded condition
E = 402.3 MPa / (-0.6993) = -575.3 GPa for the loaded condition
I hope this helps you
the first step in solving this problem would be to carefully analyze the given information and identify the relevant equations and variables. In this case, the equations for a wheatstone bridge circuit and the definition of strain are the most important.
Next, I would use the given equation for the bridge circuit (R1/R2 = R4/R3) to solve for the value of R1 when the specimen is unloaded and loaded. This will give me the change in resistance (dR) for R1.
Then, I would use the given equation for the output voltage (Vo) and substitute in the values for the input voltage (V) and the change in resistance (dR) for R1 and R2. This will give me the value of Vo when the specimen is unloaded and loaded.
To calculate the strain (e), I would use the definition of strain (e = dL/L) and substitute in the values for the change in length (dL) and the original length (L) of the specimen. The change in length can be calculated using the given diameter and the force applied (using the equation for stress).
Finally, I would use the equation for Young's modulus (E = stress/strain) and substitute in the calculated values for stress and strain to determine the value of Young's modulus for the material of the specimen.
It is important to carefully consider the units and conversions when plugging in values and to double check the calculations to ensure accuracy. Additionally, it may be helpful to draw a diagram or create a table to organize the information and make it easier to visualize the problem.
1. What is a strain gauge problem and why is it important to solve?
A strain gauge problem refers to the difficulty in accurately measuring the strain (change in length) of a material under stress. This is important because it allows us to calculate the material's Young's modulus, which is a measure of its stiffness and can provide valuable information about the material's properties.
2. How do strain gauges work?
Strain gauges are small devices that are attached to a material and measure its strain by detecting the changes in its electrical resistance. When the material is under stress, its length changes, causing the strain gauge to either stretch or compress, leading to a change in resistance which can be measured and used to calculate the strain.
3. What factors can affect the accuracy of strain gauge measurements?
There are several factors that can impact the accuracy of strain gauge measurements, including temperature changes, improper installation or placement of the gauge, and external forces affecting the material being measured. It is important to carefully consider and control these factors to ensure accurate and reliable results.
4. What is the formula for calculating Young's modulus using strain gauge measurements?
The formula for calculating Young's modulus using strain gauge measurements is E = (FL/δA), where E is the modulus of elasticity, F is the applied force, L is the length of the material, δ is the strain measured by the gauge, and A is the cross-sectional area of the material. This formula can be derived from Hooke's Law, which states that the strain of a material is directly proportional to the stress applied to it.
5. How can I improve the accuracy of my Young's modulus calculation using strain gauge measurements?
To improve the accuracy of your Young's modulus calculation, it is important to carefully calibrate your strain gauge and ensure it is properly attached and aligned with the material being measured. Additionally, taking multiple measurements and averaging them can help to reduce errors. It is also important to consider the material's behavior under varying levels of stress and make adjustments accordingly.
